Hour & Minute Hand: Straight Lines & Overlaps
The hour and minute hands of a clock form a straight line together 1176 times per day, based on their angular velocities of 2π radians per hour for the minute hand and π/6 radians per hour for the hour hand. The angle between the two hands can be expressed as θ(t) = 59πt/30, where t is the time in minutes. To find instances when the hands are straight, k must be an odd integer, leading to the conclusion that there are 1176 instances of straight alignment throughout a 24-hour period.
  • Understanding of angular velocity and its calculation
  • Familiarity with unit circle concepts
  • Basic knowledge of trigonometric functions
  • Ability to solve equations involving integers and multiples
  • Explore the concept of angular velocity in more detail
  • Learn about the properties of the unit circle and its applications
  • Investigate the mathematical principles behind clock arithmetic
  • Study the derivation of trigonometric functions and their applications in real-world problems
Mathematicians, physics students, and anyone interested in the mechanics of clock hands and angular motion.
Mk
How many times per day (00:00-24:00) do the hour and minute hand form a straight line together? Would this be the same for when they overlap? Say, the minute hand goes pi/1 hr and the hour hand goes (pi/12)/1 hr. Then what?
Mathematics news on Phys.org
Construct a function and find it's solutions according to what you are looking for. As a hint, both hand start on 12 at 0:00. Now with the frequency of each hand, can you find how does the angle between them change with time?
I've put a "solution" here. I covered it though, it's only there if you really have no reason to try solving the problem by yourself (maybe a homework?). You can highlight it to see it, but I recommend to try to come up with the solution yourself.
Assume we are dealing with a unit circle. The velocity of a hand, actually equal to it’s angular velocity because we’re dealing with a unit circle, is equal to 2π/T, where T is the period of the hand. For the minute hand we have v = 2π and for the hour hand we have v2 = 2π/60. Now note that the distance along the circle covered by a hand is equal to v*t, where t is the time elapsed in minute. Moreover, the distance between the two hands is given by the difference of the respective covered distances. Since this is on a unit circle, this distance is equal to the angle that separates the two hands. We end up with something like this as a function θ(t) = 2π*t - 2π/60*t or θ(t) = 59*π*t/30. Now, it’s obvious that if θ is to be a multiple of π, t = k*30/59, where k is any integer number. However we have to be careful. If θ is a multiple of 2π, the hands are certainly not opposite, they are overlapping. This is equivalent to saying that the value k has to be odd. Let’s solve k*30/59 = 1440 (there are 1440 minutes in day). We have k = 2352. So there are 2352 instance of the day where is a multiple of π. Now, since of have the requirement of k being odd, there 2352/2 = 1176 solutions of interest.
12K
  • · Replies 21 ·
