Two Hookean Springs Connected in Series
  • Context: Undergrad
  • Thread starter Thread starter arunma
    Series Springs
The discussion revolves around the mechanics of two Hookean springs connected in series, specifically focusing on the forces acting at the point of connection and the implications of Newton's laws in this context. Participants explore the derivation of the equivalent spring constant and the conditions under which forces are balanced at the connecting point.
  • One participant questions why the net force on the connecting point between the two springs is set to zero, given that the point accelerates.
  • Another participant suggests that the connecting point can be considered to have effectively zero mass, leading to balanced forces to avoid infinite acceleration.
  • A participant clarifies that the forces exerted by the two springs on the connecting point do not constitute an action-reaction pair in the traditional sense, as there is no massive object at that point.
  • It is noted that the two springs can be viewed as directly exerting forces on each other, which would then be considered an action-reaction pair.
  • A later reply questions the validity of stating that the net force on any individual point in a rigid body is zero, even when the body experiences net acceleration, leading to a discussion about the nature of forces on infinitesimally small parts of an object.
Participants express differing views on the nature of forces at the connecting point and the applicability of Newton's laws, indicating that multiple competing perspectives remain without a clear consensus.
The discussion highlights limitations in applying Newton's laws to individual points versus small segments of objects, emphasizing the need for a well-defined approach to analyzing forces in such systems.
arunma
I was just going through the derivation for the equivalent spring constant of two springs (of different stiffness) connected in series, and I realized that there's one thing I don't understand. In the process of this derivation, it is necessary to write down the net force acting on the point connecting the two springs, and then set this equal to zero. This seems to imply that the two forces are the action-reaction pair dictated by Newton's Third Law. My question is: why is this the case? Given that the connecting point between two springs does accelerate, why do we set the net force on this point equal to zero?
The mass of the point is (effectively) zero. When something has zero mass, the forces on it must be balanced because the alternative would (by N2) imply infinite acceleration.
Thanks, that makes sense. But do the forces of the two springs on this point constitute an action-reaction pair?
Not as such. An action/reaction pair are the two forces exerted by two objects on each other when they interact. (For example, a book sitting on a table exerts a normal force downward on the table, while the table exerts a normal force upward on the book.) So, if we're going to talk about the forces on the connecting point due to the two springs, these would be paired with the forces the connecting point exerts back on the springs.
That said, since there's no massive object sitting at the connecting point, it's just as valid to think of the two springs directly exerting forces on each other. And, in that picture, the two forces are an action/reaction pair.
Thank you. This might sound like a naive question, but is it always valid to say that the net force on any individual point in a rigid body is zero (even when the body experiences a net acceleration)?
No. What makes this special is that, in talking about the point at the interface between the springs, you're basically defining that you're not including any part of either spring. In general, it's really only valid to talk about vanishingly small bits of an object, not individual points, because we need a well-defined way to add them back together to get the whole object. So, then, we'll have infinitesimally small bits of the object with infinitesimal masses, dm. These, then, must feel a net force, [tex]dF = adm[/tex]
  • · Replies 17 ·
