| Thread Closed |
Buffer Solutions |
Share Thread | Thread Tools |
| Feb26-07, 12:11 AM | #1 |
Buffer Solutions
Can NH4Br be used to create a buffer solution? 2. Relevant equations N/A 3. The attempt at a solution I said yes because NH4+ is a weak acid, and its conjugate base, NH3 can be added to create a buffer solution. However, I am not sure whether having Br(the conj. base of a strong acid) will affect the buffer solution. Does only one of the two ions have to be a weak base/acid, or do both? |
| Mar1-07, 01:19 AM | #2 |
Recognitions:
Hydrogen halides, except of fluoride(?) become strong acids in water.
pH buffers can be made from mixing weak acid and salt of the weak acid; or mixing weak base and salt of the weak base. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Buffer Solutions
| Which of the following solutions result in a buffer ? | Biology, Chemistry & Other Homework | 1 | ||
| pH and buffer solutions | Biology, Chemistry & Other Homework | 4 | ||
| ph and buffer solutions help | Biology, Chemistry & Other Homework | 10 | ||
| Buffer Solutions | Chemistry | 2 | ||
| Buffer solutions | Chemistry | 1 | ||
