Testing AC Polarity with LED: Tip & Ring
  • Thread starter Thread starter slo
    Ac Led Polarity
The discussion revolves around testing AC polarity using an LED setup, particularly focusing on how to indicate proper polarity with color changes in the LED. Participants explore the principles of AC current flow, the functionality of LEDs in this context, and the use of bridge rectifiers for polarity indication.
  • One participant describes using a red/green LED to test continuity in phone lines, suggesting that the LED lights up red for a proper AC signal and proposes a method to indicate AC polarity.
  • Another participant argues that AC current does not have polarity since it flows in both directions, explaining that the LED behaves like a half-wave rectifier, lighting up red during one half-cycle and being blocked during the other.
  • A third participant references the principle of a diode bridge and discusses the identification of a "hot" wire in AC outlets, expressing a need for a bridge rectifier setup to indicate polarity correctly with an LED.
  • One participant emphasizes the importance of understanding circuit behavior in AC systems, noting that current flows in both directions and discussing the implications of grounding and safety in electrical setups.
Participants express differing views on the concept of polarity in AC circuits, with some asserting that polarity is not applicable while others seek methods to indicate it. The discussion remains unresolved regarding the best approach to achieve the desired LED indication for AC polarity.
There are assumptions regarding the behavior of LEDs in AC circuits and the safety implications of testing AC polarity that are not fully explored. The discussion also touches on the complexity of AC wiring scenarios without reaching a consensus on the proposed methods.
slo
We routinely test "continuity" in our phone lines by holding a red/green LED to our "tip" (hot) and "ring" (cold) which lights up bright red if all is well with the AC signal.
A bridge rectifier added to the mix let's the "green" shine; reversing the LED wires on + and - will make the "true" red light come on. All pretty simple.
There must be also be a fairly simple way to get such an LED to show proper AC polarity as well, i.e "green" if good, and "red" if "tip/ring" is reversed?
The fact that it is AC means that there is no Polarity as current flows in both directions.
The LED is acting like a halfwave rectifier so that on one half cycle it flows through the RED LED and on the other it is blocked. If you are using a two pin bi-colour LED then I can only assume that the green is swamped by the red cycle.
I was looking at the principle behind the diode bridge here:
http://en.wikipedia.org/wiki/Diode_bridge
To my understanding there is one "hot" wire in your AC wall outlet you should not touch, the "tip" as it were, that can be idenified by using a simple mains tester:
http://www.tool-net.co.uk/data/tools/scmate4950.jpg
There are more "complicated" AC outlet analysers that dislpay any possbile combination of wiring scenarios, but all I need is a bridge diode/rectifier setup that would send the ACs "hot" through a red/green LED the proper way - "green" if its on tip "red" if its on ring.
If that makes sense ;)
Electricity needs to be in a circuit to work. Current flows round all parts of the circuit, in a DC circuit it flows in one direction, in an AC circuit it flows in both directions. The Hot/Live convention does not mean that when a circuit is active current is only flowing in one conductor.
It would be possible to divert the current through the Earth connection, I believe in the US the Neutral is tied to Earth on the 110V side, In the UK it is separate and any Earth leakage has to be kept very low. You could use a low current device with suitable current limiting resistor to create a circuit between Live and Earth and Neutral and Earth. Current should flow in the former but not the latter.
This of course should not be attempted unless you have Earth Leakage protection on the supply and at least believe you know what you are doing and the implications of getting it wrong. Relying on the 100A supply fuse can be career limiting.
10K
  • · Replies 25 ·
15K
  • · Replies 34 ·
10K
9K
