Force due to wind and rolling friction on van
The problem involves analyzing the forces acting on a minivan coasting on a straight, level road while towing a boat and carrying windsurfing equipment. The objective is to determine the force due to wind and rolling friction at a specific speed of 44.17 mph, given the vehicle's mass and weight.
  • Participants discuss the need to find instantaneous acceleration from a graph, with one expressing uncertainty about how to derive this from the graph. There is mention of using the derivative and drawing a tangent line to find the slope at a specific point.
The discussion is focused on understanding how to calculate instantaneous acceleration from a graph. Some participants have provided guidance on drawing a tangent line to determine the slope, while others are still grappling with the concept of deriving a function from a graphical representation.
Participants are working under the constraints of a homework assignment, which may limit the resources they can use. There is an emphasis on understanding the graphical representation of motion and its implications for calculating forces.
fruitl00p
The graph shows the speed as a function of time for a minivan, coasting on neutral along a straight, level road, loaded with windsurfing equipment and towing a boat. The total mass is 2500 kg, weight= 5512lbs. Find the size of the force due to wind and rolling friction when the van speed is 44.17 mph. (1 mph=0.447m/s)
F=ma
I don't think anyone needs to see the graph to understand my problem. Well I hope.
I understand that a= delta v/delta t. But whenever I use the equation I get an acceleration that does not work. Then I thought that since the equation wants the force at 44.17 mph, that I need to find the instantaneous acceleration.
That's my problem: I don't know how to get the instantaneous acceleration. At 44.17 mph the time is at 19 s. Should I create a derivative. If so, how do I go about it?
The answer for this problem is 764 N
Please tell me why my approach is incorrect.
That's right, calculate the instantaneous acceleration by finding the derivative of the graph at the given time. You must be able to find a way to do that (draw a tangtent).
Good luck!
da_willem, that is my problem. I do not know how to find the derivative of the graph. If I am given a derivative, I can do it; but to look at a graph and create one I just don't know.
In the graph you draw a line tangential to a point where you want to know the derivative (a 'tangent line'). The derivative in that point is now the 'slope' of this line, i.e. a vertical interval ([itex]\Delta v[/tex]) divided by a corresponding horizontal interval ([itex]\Delta t[/tex]): ([itex]\Delta v /\Delta t[/tex]).[/itex][/itex][/itex]
I got it now. Thank you da_willem
  • · Replies 42 ·
9K
  • · Replies 97 ·
