Thread Closed
collison betwen two balls
Share Thread
Feb27-07, 04:19 PM   #1
Two identical steel balls, each of mass 1.4 kg, are suspended from strings of length 36 cm so that they touch when in their equilibrium position. We pull one of the balls back until its string makes an angle q = 36° with the vertical and let it go. It collides elastically with the other ball. How high will the other ball rise?
ok so what i am using is pi=pf and ei=ef
first i calcuate the velocity of of th first ball when it is just about to hit the second which is
mgh=1/2mv^2
(1.4)(9.8)36cos36=1/2(1.4)v^2
then v=23.89
so pi=pf of the system so m1v1+m2v2=m1v1f+m2v2f
which is (1.4)(23.89)+0=0+1.4v2f
so v2f=23.89 and if that is true, wouldn't ball 2 go as high as ball 1?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb27-07, 04:26 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Rasine View Post
mgh=1/2mv^2
Reconsider the red step.
Feb27-07, 04:57 PM   #3
would it be 36sin56 instead?
Feb27-07, 05:02 PM   #4
Recognitions:
I suggest you draw a diagram on this one.
Feb27-07, 05:09 PM   #5
well i want to find the lenght in the y direction and i see 2 ight triangles i could get y from 36cos36 or take 90-36=56 and do 36sin56
Thread Closed
Similar discussions for: collison betwen two balls
Thread Forum Replies
Equivalence betwen diferent definitions of charge Beyond the Standard Model 0
Different meanings betwen General Discussion 4
Red Balls, Green Balls and Expectations Set Theory, Logic, Probability, Statistics 2
Collison of Billiard Balls General Physics 4
collison Introductory Physics Homework 5
