How Is Work Calculated for Permanent Magnets on Iron Plates?
The discussion focuses on calculating the work done by permanent magnets on iron plates, exploring the relationship between force, distance, and the thickness of the plates. Participants raise questions about the mechanics of magnetic attraction, the impact of distance on force, and the conditions under which work is done.
  • One participant inquires about the calculation of work done by a permanent magnet on an iron plate, questioning the role of surface area and thickness of the plate.
  • Another participant states that work is calculated as force times distance, emphasizing that static forces do not perform work.
  • A participant notes that the force exerted by a magnet increases as the distance decreases and suggests that a formula accounting for increasing magnetic flux might be necessary.
  • Concerns are raised about the kinetic energy gained by a ferromagnetic plate when attracted to a magnet and the minimum thickness required for the plate to fully utilize the magnet's force.
  • One participant proposes using conservation of energy to relate the work done by the magnet to the weight of the object and its vertical displacement.
  • Another participant mentions the complexity of integrating force over distance when the plate is not initially close to the magnet, referencing an inverse-square relationship between distance and force.
  • There is a discussion about determining the minimum thickness of the plate through an analogy with electrostatics, involving charged disks and their distances.
  • A participant recalls a claim from a permanent magnet manufacturer regarding the necessary thickness for effective attraction, suggesting that beyond a certain point, thickness may not significantly affect the magnetic field's influence.
Participants express varying views on the relationship between thickness and magnetic force, as well as the calculation of work done by magnets. No consensus is reached on the exact formulas or conditions required for these calculations.
There are unresolved assumptions regarding the definitions of "full force" and the specific conditions under which the calculations apply. The discussion also highlights the complexity of the mathematical relationships involved.
korneld
Hi,
I have two questions about permanent magnets:
1. How do you calculate the work done by a permanent magnet on, say, an iron plate?
2. I am aware that the force exerted on an object by a magnet depends on the surface area. Is it also affected by the thickness of the object to a certain extent? What is the minimum thickness after which thickness is not an issue?
Thanks.
The work is force times distance (when linear) or better, the integral of force to the distance it acted upon.
Thickness of what, the metal plate of the magnet.
Thanks for that.
But the problem is that the force increases as the distance between the objects decreases. I thought there might be a formula that takes the increasing flux into account.
Second, I meant to ask about the thickness of the plate.
It is an inverse-square relationship between distance and force.
Btw, your OP asks about work. You do understand that work is force times distance moved, right? Static forces do no work.
Yes, no movement means no work done.
What I am looking to find out is if a ferromagnetic plate is "sucked in" by a magnet, how much kinetic energy is gained. Also, what the minimum thickness of this plate would have to be to take advantage the full force of this magnet.
Use conservation of energy, viz. the work done by the magnet is equal to vertical component of its displacement multiplied by the objects' weight.
Unless the plate starts out very close to the magnet, you have to do a complicated integral of F(x)dx. The force ~1/7 (like Van der Waals) at large distance and becomes indep of x when x<<R (for a magnet with end radius R).
You can decide on the miimum thickness of the plate by solving the following
electrostatics problem: Consider two parallel identical uniformly charged
disks of radius R, a distance L apart. When the distance x above one disk is large enough so that you can neglect the charge on the other plate is the same as when the plate is thick enough. The plate thickness L will depend on x, R and what you mean by "full force"
Thanks for the info.
'... and what you mean by "full force"': I've read on one permanent magnet manufacturer's website (which now I can't seem to find) that the material to be attracted by the magnet has to to have a certain thickness, but beyond that point thickness is irrelevant. I am assuming that below it, the magnetic field will have a lesser effect on the material.
  • · Replies 21 ·
10K
