Proving Boundedness of Symmetric Operator on Hilbert Space
The discussion centers on proving the boundedness of a symmetric operator A on a Hilbert space X, where D(A) = X and (Ax, y) = (x, Ay) for all x, y in H. It is established that if A is symmetric and defined everywhere, it is self-adjoint and closed, leading to the conclusion that A is continuous and thus bounded. The Hellinger-Toeplitz theorem is referenced, confirming that unbounded symmetric operators cannot be defined on the entire Hilbert space.
  • Understanding of Hilbert spaces and their properties
  • Knowledge of symmetric and self-adjoint operators
  • Familiarity with the closed graph theorem
  • Concept of operator continuity in functional analysis
  • Study the Hellinger-Toeplitz theorem in detail
  • Learn about the closed graph theorem and its implications for operators
  • Explore the properties of self-adjoint operators in Hilbert spaces
  • Investigate the relationship between boundedness and continuity of linear operators
Mathematicians, graduate students in functional analysis, and anyone studying operator theory in Hilbert spaces will benefit from this discussion.
Pietjuh
Let A be a linear operator on a Hilbert space X. Suppose that D(A) = X,
and that (Ax, y) = (x, Ay) for all x, y in H. Show that A is bounded.
I've tried to prove it by using the fact that if A is continuous at
a point x implies that A is bounded.
Suppose that x_n converges to x.
|| Ax_n - Ax ||^2 = || A(x_n - x) ||^2 = ( A(x_n - x), A(x_n - x) ) =
(x_n - x, A^2 (x_n - x) ) <= ||x_n - x || || A^2(x_n - x) ||
But i don't think I can conclude from this that because ||x_n - x|| -> 0, this expression goes to zero, since || A^2(x_n - x) || may blow up.. Or doesn't it?
Please help me :)
D(A)=domain of A? I don't see how you can prove this. Self adjointness doesn't imply boundedness. You must be assuming A is also continuous? Then there is not much to prove. Better check the question.
In a Hilbert space bounded <=> continuous. If A is symmetric and everywhere defined, it's equal to its adjoint, hence self-adjoint hence closed. By the closed graph theorem, it is also continuous, end proof.
The theorem you needed to prove is called "The Hellinger-Toeplitz theorem" and proves that unbounded symmetric operators cannot be defined on all [itex]\mathcal{H}[/itex].
  • · Replies 43 ·
