Car Jack Torque Calculation - 100kg
  • Thread starter Thread starter akueddy
    Car
The discussion revolves around calculating the torque required for an electrical scissors jack designed to lift a load of 100 kg. Participants explore the necessary considerations for selecting an appropriate electric motor based on torque calculations.
  • One participant inquires about the method to calculate the torque needed for lifting a 100 kg load with an electric scissors jack.
  • Another participant asks for clarification on whether the mechanism is hydraulic or jack-screw, indicating the importance of the type of jack in the calculations.
  • A later reply specifies that the jack is a scissors jack and suggests starting with an assumption of zero friction in the screw mechanism.
  • Participants discuss the importance of selecting a typical screw pitch used in normal scissors jacks and determining the gear ratio based on the screw pitch and its effect on the scissors' movement.
  • There is a recommendation to calculate the zero-friction torque first and then incorporate friction effects, assuming lubrication on the screw, to find the total required torque.
  • It is mentioned that the electric motor should likely have a gearbox output to assist in the torque application.
Participants have not reached a consensus on the specific calculations or methods for determining the torque, and multiple approaches and considerations are presented.
Assumptions about friction, screw pitch, and gear ratios are discussed, but the specific values and their implications remain unresolved.
akueddy
hi,
i am designing an electrical car jack, my question is before i choose the proper electric motor, how do i calculate the torque require to lift the load, let say 100kg.
ops sorry, it is suppose to be a scissors jack.
Start off assuming zero friction in the screw mechanism, and decide what pitch screw you will use. You should probably stay with the typical screws found in normal scissor jacks to start. Then figure out the gear ratio that you get via the pitch of the screw and how that moves the scissors.
Once you've found the zero-friction torque required, go back and add in the friction term (assuming lubrication on the screw) to see how much that adds to the required torque. Your electric motor should probably also have a gearbox output, I would think.
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 21 ·
