Guide with Forces, Motion, Newton's Laws & Momentum
This discussion focuses on a physics assignment centered around the concept of momentum and the external forces acting on a system. The assignment requires students to conduct experiments using a tennis ball, stopwatch, and tape measure to gather data on the ball's motion. Key elements include calculating the retarding force, understanding Newton's laws of motion, and addressing potential sources of error in the experiment. The conclusion emphasizes the importance of explaining results in relation to theoretical principles and personal reasoning.
  • Understanding of Newton's First and Second Laws of Motion
  • Basic knowledge of momentum and its calculations
  • Familiarity with experimental design and data collection methods
  • Ability to analyze and interpret graphical data
  • Research the mathematical formulation of momentum and its conservation
  • Study the impact of external forces on motion using free-body diagrams
  • Learn about common sources of error in physics experiments and how to mitigate them
  • Explore graphical analysis techniques for velocity vs. time plots
Students studying physics, educators preparing lab assignments, and anyone interested in understanding the practical applications of Newton's laws and momentum in experimental settings.
blaziken's_charizard
I'd like guidelines on how to go about my assignment. I don't need the answers to the quetions, but rather an explanation on what should be in the answer. Below is the assignment, I need help with the bolded part of the quote and nothing else. Thanks a lot! The ictalized parts are what I'm done with.
Title:
Momentum
Aim:
To find the external force acting on a system
Theory
Materials and apparatus
A tennis ball
a stop watch with accuracy to 0.01s
a tape measure
and if possible a pool stick cut I am sure we will be able to substitute something.
Method.
1. Mark a straight line alone a floor in a relatively large room
2. Along that line, mark an x every 15cm
3. Place the ball at one end of the line and with a stick or something to that effect, push it with a suitable force
4. Time how long it takes to complete every 15cm interval until the ball stops
5. Repeat the above 4 more times
6. Place the data into the table below
7. Find the mass of the ball
8. Do calculations
9. Plot a graph – velocity against cumulative time
Results
Distance interval /m Exp I – t/s Exp 2 –t/s Exp 3 – t/s Exp 4 –t/s Exp 5 –t/s Ave t/s Velocity C. time
0.15
0.30
0.45
0.60
0.75
0.90
1.05
1.20
1.35
Discussion
What is a force?
Is there a force being applied here, if yes, what?
Explain the rationale of your method
Explain applications on knowing the force being applied
State sources of error, limitations and precautions
Explain what is going on in relation to Newton’s first and second law of motion – including momentum
Explain how this proves Aristotle’s law wrong
Any other business that you may see fit
Conclusion
The value of the retarding force acting on the tennis ball is _______N
What do you think? You didn't offer your opinion on what you think should be there. Is this the first time you've written a lab report? Those are pretty specific questions, so that makes it fairly straightforward. The point of the discussion is to explain the results in terms of the laws you are investigating (do they agree? why/why not?) and to show you understand what's going on. Just answer the questions and explain your reasoning. Read your textbook for relevant material. I'm sure you must have some ideas about your sources of error/limitations since you were the one taking the measurements. Explain what they are and what impact they may have had on your experiment.
  • · Replies 27 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 17 ·
