Two point charges electric field
The discussion revolves around calculating the electric field at the midpoint between two point charges, specifically a negative charge of −14.0 µC and a positive charge of +13.0 µC, which are separated by a distance of 7.40 cm.
  • Participants explore the correct equations for calculating electric fields rather than forces, questioning the original poster's use of the force equation. There is discussion about calculating the electric field contributions from each charge at the midpoint and the need for vector addition.
Participants have provided guidance on the appropriate equations to use and emphasized the importance of unit consistency. There is acknowledgment of the original poster's confusion regarding the calculations, and some participants suggest checking the distance from each charge to the midpoint and ensuring proper unit conversions.
There are indications that the original poster may have miscalculated distances and units, particularly in converting from centimeters to meters and in the representation of charge magnitudes.
kbyws37
What are the magnitude and direction of the electric field midway between two point charges, −14.0 µC and +13.0 µC, which are 7.40 cm apart?
I used the F = ((k)(q1)(q2))/r^2
F= ((9x10^9)(-14)(13))/(7.40^2))
F= 2.99 x 10^10
however that answer is wrong. (The correct answer is 177000000 N/C).
Which equation am I suppose to use?
The equation you have there is for the force between two point charges, not the electric field due to a point charge. Take another look at your notes and see if you can figure out which equation it should be. You need to consider the force due to each charge at the centre, i.e. the electric field at the centre due to Q1 and the electric field at the centre due to Q2. It is a vector quantity. Make sure you are consistent with your units.
hage567 said:
The equation you have there is for the force between two point charges, not the electric field due to a point charge. Take another look at your notes and see if you can figure out which equation it should be. You need to consider the force due to each charge at the centre, i.e. the electric field at the centre due to Q1 and the force at the centre due to Q2. It is a vector quantity. Make sure you are consistent with your units.
So i would use the equation
F= ((k)(q))/r^2
so would i perform this equation twice? once for q1 and once for q2?
sorry, i am still not understanding
It isn't "F", it's "E".
Yes, that is the equation to use. You need to use it for both charges. The resultant electric field at the midpoint will be the vector sum of the fields from the two charges, E=E1+E2.
I used the equation for both charges but still didn't get the right answer
E1 = ((9x10^9)(-14) / (7.4^2)) = - 2.3 x 10^9
E2 = ((9x10^9)(13) / (7.4^2)) = 2.14 x 10^9
E = (- 2.3 x 10^9) + (2.14 x 10^9) = 1.6
(correct answer should be 1.77 x 10^8)
You don't have the correct value for r. If the distance between the two charges is 7.4 cm, what is the distance from each charge to the midpoint of their separation?
Also, you are not being consistent with the magnitudes of the quantities. 14uC needs to be 14x10^-6 C, so your units work out. Do you see what I mean? Include your units in the calculation so you can make sure they work out properly. Check your conversion from cm to meters as well (you must do this).
thank you! you explained it very well and i won't forget converting my numbers! :)
You should have all the information now to get the answer. Just put it all together in the right way!
  • · Replies 68 ·
9K
