What is the difference between Ave. and Instantaneous Speed?
  • Context: High School
  • Thread starter Thread starter gmommy
The discussion revolves around the concepts of average speed, instantaneous speed, and the distinction between speed and velocity. Participants explore definitions, provide examples, and clarify the mathematical relationships involved, focusing on both theoretical and conceptual aspects.
  • One participant questions the meaning of "magnitude" and the differences between average speed and instantaneous speed, as well as between average and instantaneous velocity.
  • Another participant explains that average speed is the constant speed needed to travel from one point to another, while instantaneous speed refers to the speed at a specific moment in time.
  • A different participant elaborates on the distinction between speed and velocity, noting that velocity is a vector quantity that includes both magnitude and direction, while speed is a scalar quantity that only includes magnitude.
  • The concept of magnitude is described as the "length" of a vector, with an example involving velocity components and the use of the Pythagorean theorem to calculate speed from velocity.
Participants generally agree on the definitions of average speed and instantaneous speed, as well as the distinction between speed and velocity. However, the discussion remains open-ended regarding the deeper implications of these concepts, and no consensus is reached on the participant's initial confusion about magnitude.
The discussion includes various assumptions about the definitions of speed and velocity, and the explanations provided rely on specific examples that may not cover all scenarios. The mathematical steps involved in calculating speed from velocity components are not fully resolved.
This discussion may be useful for beginners in physics who are trying to understand the fundamental concepts of speed and velocity, as well as those seeking clarification on the differences between average and instantaneous measures.
gmommy
This is in my book.
Speed and velocity are defined by the following equations ..
Limit statements:
The magnitude of an object's velocity approaches its speed as the time interval approaches zero:.
Thus, the instantaneous speed of an object is the magnitude of its instantaneous velocity: v = |v|.
This is my question/s
What is the magnitude? I don't know what the mag. is OR the difference between Ave. speed and instantaneous speed
OR between Ave. and Instantaneous Velocity.
I know this probably seems like a moron question to you guys but I have just started physics. I can't find a way to 'GET' these equations.
Thank you, in advance.
Don't be worried about asking a "moronic question". We're here to help for the most part.
Average speed is basically the speed you would need to go at constantly to get from point A to point B. It's like If I was to travel by car to detroit. My average speed would be somethingn like 30 miles per hour, even though at times I was going 60 and at times I was stopped.
Instantaneous speed is the speed at any given instant. Think of it like this:
If you are accelerating at 1 meter/s^2, which is the same as saying "1 meter per second" "per second". Each second the speed increases by 1 meter per second. At time=1 second, the speed is 1 m/s. At 2 second, it's 2 m/s. At 3, it's 3. But see, the speed changes each second, that's why those are called instantaneous. At any other time, the speed may be different.
In the detroit example, being stopped might be an instantaneous speed, because I didn't get to detroit with the car stopped. But I was stopped for at least an instant.
Does that help?
Since Decker has already handled "instantaneous" versus "average", I'll look at "speed" versus "velocity".
To a physicist, "velocity" is a vector. It's not enough to say "45 miles per hour" (that's a "speed"). A velocity would have to be "45 miles per hour North, NorthEast". That is both a "magnitude" (how big it is) and a direction. The magnitude of a vector is simply its "length". I put "length" in quotes because, of course, if we are talking about velocity, it is not really "length". But that's a good way of thinking about it.
If an object is moving, in some laboratory experiment, with a speed of 10 m/s, at an angle of 45 degrees to a give "x-axis", then I can represent its velocity either by saying "10 m/s at 45 degrees to the x-axis" or by giving its "components": I think of the velocity vector as an "arrow" with length 10 (m/s though that really doesn't make sense for a "length"!) at an angle of 45 degrees to the x-axis. Drawing in the lines parallel to the x and y axes, I get a right triangle. Since sin(45)= cos(45)= &radic;(2)/2 (That's why I chose 45 degrees!), the two legs of the triangle have length 10(&radic;(2)/2)= 5&radic;(2). Those are the "x" and "y" components of the velocity. We might write that as <5&radic;(2),5&radic;(2)>
The speed is the "length" or magnitude of that vector. If we had been given the velocity as <5&radic;(2),5&radic;(2)>, we could calculate the speed by again visualizing that right triangle and using the Pythagorean theorem: the magnitude of the velocity vector (speed) is the length of the hypotenuse: &radic;((5&radic;(2))2,(5&radic;(2))2)= &radic;(50+ 50)= &radic;(100)= 10.
DECKER & HALLS OF IVY
Thank You. I understand much more than I did PRE- Physics Forums.
Thank You for helping all of us out here. gmommy.
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 40 ·
  • · Replies 29 ·
