Sound Experiment: Dropping 4 Masses from a 3rd Floor Window
  • Context: High School
  • Thread starter Thread starter KingNothing
    Experiment Sound
The forum discussion centers on an extra credit project involving the dropping of four 100kg masses from a third-floor window using a 3-meter string. Participants must measure the sound of the masses hitting the ground and achieve a 98% correlation with a straight line using Graphical Analysis software. Key considerations include the arrangement of masses to ensure consistent timing between impacts and the method of measuring time accurately, as traditional stopwatches may not suffice for the required precision.
  • Understanding of free fall physics and gravitational acceleration.
  • Familiarity with sound measurement techniques and timing accuracy.
  • Experience with Graphical Analysis software for data correlation.
  • Basic knowledge of mass distribution and its effects on impact timing.
  • Research methods for precise timing measurement in physics experiments.
  • Explore the principles of free fall and its impact on falling objects.
  • Learn advanced features of Graphical Analysis for data analysis and correlation.
  • Investigate the effects of mass and distance on sound propagation and timing.
This discussion is beneficial for physics students, educators, and anyone involved in experimental design and data analysis, particularly in the context of sound measurement and free fall dynamics.
KingNothing
Hey everybody. We have this extra credit project due friday. The conditions are as such:
We use a 3 meter string and hang 4masses on it with the distance being no less that .5m apart. We can use masses in variations of 50kg, but he suggested we use all 100kg masses.
We drop the string from a 3rd floor window, and the sound of the masses hitting the ground is measured versus time. We use that graph with a program called graphical analysis, and we must achieve a correlation of 98% with a straight line.
Put simply, the time between the sound of each one hitting must be about constant.
I'm not really sure about anything else. We are allowed to use sources such as this fine forum, so I'm thankful for that. What suggestions do you guys have?
Thank you in advance. Love you guys.
Now, my idea was to have the masses arranged so that there is a smaller distance between the ones that will be hitting first and a larger between the last ones.
50 kg and 100 kg masses on a string?! Pretty tough piece of string!
Seriously though, have you thought about how you will measure time? Stopwatches probably won't cut it for a correlation of 98%. If you can solve that problem you should be ok.
On the right track, I think. and you can calculate how much longer weights 2 and 3 will be in freefall to determine how much faster each one will be going when it hits, this will tell you how much farther apart they need to be.
Or, you could hold the string perfectly horizontal and drop it. All three weights hit the ground simultaniously (from the lab's inertial frame of reference, of course), so the time interval between 1 and 2 = 0, and the time interval between 2 and 3 = 0. The success of this matheod depends on three main factors; 1) how precisely horizontal can you hold the string? 2) How precisely can you syncronise release of the two ends, and 3) The disposotion of your prof.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 47 ·
10K
  • · Replies 16 ·
