B.) Mass Defect & Binding Energy for Astatine 21885At
  • Thread starter Thread starter StudentofPhysics
    Mass Mass defect
The discussion revolves around calculating the mass defect and binding energy for the isotope astatine-218 (21885At). Participants are attempting to derive the mass defect in atomic mass units, the binding energy in MeV, and the binding energy per nucleon.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of mass defect, questioning the inclusion of electrons in the mass calculations. There are various attempts to convert units from atomic mass units to kilograms and then to energy units (Joules, eV, MeV). Some participants express confusion about the correct values and methods to use.
Several participants have provided guidance on unit conversions and the importance of using precise atomic weights. There is a mix of interpretations regarding the inclusion of electrons and the correct approach to calculating binding energy. Some participants report arriving at different numerical results, prompting further exploration of their calculations.
Participants mention discrepancies between their calculations and textbook values, indicating potential confusion over the definitions or assumptions in the problem. There is also a reference to the availability of educational resources in different countries, which may influence the discussion.
StudentofPhysics
1. For astatine 21885At (atomic mass = 218.008684 u) obtain each of the following:
(a) The mass defect in atomic mass units
wrong check mark u
(b) the binding energy (in MeV)
MeV
(c) the binding energy per nucleon (in MeV)
MeV
2. Shown in atempt
3. ok, I don't see how I'm wrong here:
A.)
218 - 85 = 133 = # of neutrons
85(1.6726 x 10^-27 Kg) + 133(1.6749 x 10^-27 Kg) = 3.649327 x 10^-25 Kg
(3.649327 x 10^-25 Kg) / (1.6605 x 10^-27 Kg) = 219.772779 u
219.772779 u -218.008684 u = 1.764095 u.
This is not correct. What am I doing wrong?
I think you have to include the electrons.
The numbers are easier if you keep it all in MeV instead of kg.
mass defect takes place in the nucleus though
You do include the electrons..
mass defect = (z*massproton+n*massneutron)-(matom-z*masselectron)
use units..
binding energy = massdefect*C^2
1 unit is approx = 931,494 MeV use that its easier
but remember to use the right atom weight not the one in the periodic table, cause its an average of the percentage of the isotopes in nature (or something like that)
ok i'll try that but my book says nothing about including electrons
ok its right thanks
no idea why my book left that out..money well spent
you should study in Denmark.. we get the books for free.. until University (college?)
ok I'm getting it equals 34.8 MeV and this isn't right
what am I doing wrong here.
Again, my book shows how to convert from kg in J then into eV then into MeV.And I had to use u because that was the required unit in the first part of the problem
As do we in America, I'm in college.
all right.. the first result was in units and correct right?
take it and and make it into kg by: 1 u = 1,6605655*10^-27kg
and then make it into joule by: x kg * (3*10^8)^2 this is just c squared
and make the joule into eV by: 1eV = 1,602189*10^-19 J
and of course into MeV by mega means 10^6
thats what I did...
hmmmwould you mind running it quickly and seeing if you get a number other than 34.8 MeV?
the correct answer in u was 1.810725 u for the mass defect
i did the following:
1.810725 u x 1.6605 x 10^-27 Kg = 3.00671 x 10^-27 Kg
3.00671 x 10^-27 Kg x (c^2) = 5.5715 x 10^-12 J
5.5715 x 10^-12 J / 1.6 x 10^-19 J = 34821826.4 eV = 34.82 MeV
If i do like this i get:
1.810725 u * 931,494 MeV/u = 1686,68 MeV
don't know if that's the correct answer :S
i also get this
but then i get 2,70614*10^-10 J
and then of course: 1,68903 *10^9 eV = 1689,03
almost the same as the other result, but used more decimals with this one.,. got to be right
I'll write it with all the decimals:
1,810725*1,6695655*10^-27 = 3,00683*10^-27 kg
3,0068274649875*10^-27*(3*10^8)^2 = 2,70614*10^-10 J
(2,7061447184888*10^-10)/(1,602189*10^-19) = 1,68903*10^9 eV = 1689,03 Mev
ok its correct, I'm going back through it all to see what we did differently.
hmm, rerunning it i get the 2.7 x 10^-7 Joules too, not sure how i got the other number the first time... maybe I wrote it down wrong
yea that's what happened I guess or I must've entered it wrong in my calculator some how...
anyway, much appreciation for the help.
Always a pleasure to help (other) students.. :) even though I'm just in high school
10K
10K
  • · Replies 0 ·
