Thread Closed
Superposition Diagram Reduction
Share Thread Thread Tools
Mar5-07, 06:10 PM   #1
Please click the image to enlarge it
I'm having trouble seeing how this circuit was reduced. Can anyone shed some light on it for me?
My question pertains to the second solution in the image. I see that the 12k and 4k resistors are in parallel and that leads to the second diagram on the bottom. Why is the 6k resistor drawn up there? When I try to redraw the circuit, I keep it just like the first one- with the exception that the 12k and 4k resistors are combined on the rightmost branch- with the 6k and the current source in the same place. When the 6V source is shorted out why is there a need to redraw that branch?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar6-07, 10:17 PM   #2
I thought about your problem today while at work and realized that the 4K Ohm resistor and the 12K Ohm resistor on the right are in parallel. Look at them, both resistors connect at both ends (directly and through the short): The definition of parallel. Once they are combined in parallel, you can twist the circuit around and get the final result without much effort.
(If you still have trouble seeing it, pull the upper ends of the two resistors until they touch and then yank them over to one side. Keep in mind that the 6K resistor is connected to both ends of the current source and the parallel resistors connected on only one end as is the other 12K. Twist it around. You'll see it.)
(I deleted my original solution because it is too complicated -- this is simplier)
Thread Closed
Thread Tools
Similar Threads for: Superposition Diagram Reduction
Thread Forum Replies
Is the Loedel Diagram a Special Case of the Minkowski Spacetime Diagram? Special & General Relativity 11
Block Diagram Reduction Electrical Engineering 3
Difference between Block diagram, Flowsheet and Flow diagram Engineering Systems & Design 1
How to get better at row reduction? Calculus & Beyond Homework 8
Proving the superposition of initial conditions gives superposition of motion Introductory Physics Homework 2
