Physics of Air Fans: Number of Blades & Flow Rate
  • Context: High School
  • Thread starter Thread starter C_S
    Air Fan Physics
The discussion revolves around the physics of air flow in relation to fan design, specifically focusing on the number of blades and blade surface area. Participants explore how these factors influence flow rate in different types of fans, including domestic and jet engines.
  • One participant questions how air flow is affected by fan design, particularly regarding the number of blades and blade surface area, suggesting that increased surface area may lead to increased flow.
  • Another participant proposes that a fan with a steeper blade pitch should achieve a greater flow rate at the same RPM, as it would move a larger volume of air with each revolution.
  • Discussion includes observations about high-tech GE jet engines, noting their steep-pitched blades and numerous blades, and questioning the reasons for these design choices.
  • A participant explains that the steep pitch in jet engines is necessary due to the forward velocity of the engine, which affects how the blades interact with the air, contrasting this with domestic fans that operate under different conditions.
  • There is a mention of a compromise in the number of blades, where more blades can reduce the work each blade must do but may also restrict air flow if too many blades are present.
  • Participants note that large jet engines typically have a similar number of fan blades, suggesting a design standard based on operational conditions.
Participants express various viewpoints on how blade design affects air flow, with no consensus reached on the optimal design parameters or the implications of different configurations.
Participants do not provide specific definitions or assumptions regarding terms like "flow rate" or "blade pitch," and the discussion does not resolve the mathematical or physical principles underlying these concepts.
C_S
hey guys,
I'm new here but i was a bit stuck on thinking about how air flow is effected by a fan. it's probably a really simple question, but it's got my cobwebbed brain a bit stumped!
my question is in two parts:
1. how does air flow relate to the design of a fan? ie, an answer with respect to the number of blades and blade surface area is what i am after. i have a feeling that if you increase the fan blades' surface area in any way, you therefore increase flow?
2. following on, if you have two separate axial flow fans whose dimensions are completely different, but turning at the same speed and have the same overall blade surface area, will you see both fans flow the same amount of air?
thanks in advance for any help
cheers
Regarding #2, I think that one with 'steeper' pitch to the blades should have a greater flow rate at the same rpm. It bites off a bigger chunk of air during each revolution.
Those higher-tech new GE jet engines have really steep-pitched blades and very many. Jet engines all have very many blades close together. Why is that?
The reason for the steep pitch is because the engine has a velocity forwards, which is equivalent to the air having a velocity backwards relative to the fan. If the pitch was shallow, the blades would effectively block off the front of the engine. A typical "domestic" fan (e.g. a room fan, or the cooling fan on a car radiator) doesn't have air already flowing towards it at hundreds of meters per second, so the blade pitch is more shallow.
The number of blades is a compromise. When you design a fan like that you want to do work on ALL the air that goes through it. If there are more blades, each blade has to do less work, therefore the forces and stresses in the blade are smaller, so the blades can be made lighter. On the other hand if there are too many blades, they block up too much space and that restricts the amount of air that can get through the gaps between them.
You don't say which particilar GE engine you are talking about but most large jet engines have a similar number of fan blades - usually between about 22 and 26. It's not surprising the numbers are similar, all the fans are working in the same air at similar RPM and at similar aircraft forward speeds.
  • · Replies 30 ·
  • · Replies 17 ·
