Rolling Ball Analysis - Mass, Length, Time Calculations
The discussion focuses on analyzing the motion of a ball rolling down a ramp, specifically a 120cm ramp with a ball mass of 0.02815kg and a diameter of 19mm. Key calculations suggested include determining the ball's acceleration, velocity at various points on the ramp, and the impact of friction on travel time. These calculations are essential for understanding the dynamics of the system and improving the analysis of rolling motion.
  • Basic physics concepts of motion and acceleration
  • Understanding of friction and its effects on motion
  • Knowledge of kinematic equations
  • Familiarity with measuring time and distance in experiments
  • Calculate the acceleration of the ball using kinematic equations
  • Determine the velocity of the ball at the top, middle, and bottom of the ramp
  • Analyze the effects of friction on the ball's motion
  • Explore energy conservation principles in rolling motion
Students and educators in physics, engineers involved in motion analysis, and anyone interested in experimental mechanics and dynamics of rolling objects.
Magg$
Hi, I am doing some analysis into a ball rolling down a ramp which is raised and lowered to different heights, and the time the ball takes to travel the length of the ramp is recorded. The ramp is 120cm long, and the ball has a mass of 0.02815kg and diameter of 19mm.
I am trying to find some calculations, and poins which I can make about this set up, but so far have only very basic calculations.
If you know of anything I can talk about, or calculate, then any suggestions are greatly appreciated.
Thankyou...
Magg$
Hi Magg,
I suggest trying to calculate the acceleration of the ball as it goes down the ramp. You could also calculate the velocity of the ball at different points (e.g. at the top, bottom, and middle of the ramp). You could also take into account the friction generated between the ball and the ramp surface to see how this affects the time taken for the ball to travel the length of the ramp.
Hope this helps!
11K
  • · Replies 60 ·
