What is the initial capacitance of a computer keyboard key?
  • Thread starter Thread starter stylez03
    Change
The discussion revolves around the initial capacitance of a computer keyboard key, which functions as a parallel-plate capacitor. The problem involves understanding the relationship between the area of the plates, the separation distance, and the resulting capacitance changes when the key is pressed.
  • Participants explore the formula for capacitance and its change, questioning the correct application of symbols and units. There is uncertainty regarding the initial capacitance calculation and the specifics of the problem statement.
The discussion is ongoing, with participants seeking clarification on the problem's requirements and the correct interpretation of the equations involved. Some guidance on unit conversions has been provided, but there is no consensus on the initial capacitance value yet.
Participants note the absence of a complete problem statement and express confusion regarding the use of symbols in the equations. There is also a mention of potential issues with unit conversions that may affect the calculations.
stylez03
In one type of computer keyboard, each key holds a small metal plate that serves as one plate of a parallel-plate, air-filled capacitor. When the key is depressed, the plate separation decreases and the capacitance increases. Electronic circuitry detects the change in capacitance and thus detects that the key has been pressed. In one particular keyboard, the area of each metal plate is 50.5 mm^2, and the separation between the plates is 0.660 mm before the key is depressed.
[tex]\Delta C = \frac {e_{0}A} {s_{1}} - \frac {e_{0}A} {s_{0}}[/tex]
[tex]\Delta s = s_{0} - s_{1} => s_{0} *(1 - \frac {1} {1 + \frac {s_{0} \nabla C} {e_{0}A}})[/tex]
I'm not too sure if this is correct, and I'm very bad at the unit conversion and I think that also might be an issue
is [tex]C = 0.300 * 10^{-12}[/tex]
Sorry, you haven't stated the full problem. What are you supposed to do? Are you given a final (smaller) separation distance, and asked to find the initial and final capacitances? Or given a target change in capacitance, and asked to solve for the final separation distance?
Also, the "Delta" symbol would usually be used for "change". You've used the "del" or "nabla" symbol above in your post, and del has a different meaning than Delta. Small nitpick, but it confused me when I first saw your post.
Delta = [tex]\Delta[/tex]
Finally, to help you with units and unit conversions, just multiply them out like they were variables. Like, velocity is distance per time, or:
[tex]v [m/s] = \frac{\Delta x [m]}{\Delta t <s>}</s>[/tex]
And if you need to convert microseconds to seconds or something, just multiply through by one (like 1s = 10^6us), like this:
[tex]\Delta t <s> = \Delta t [\mu s] \frac{1 <s>}{10^6 [\mu s]}</s></s>[/tex]
Sorry I left out the actual question:
If the circuitry can detect a change in capacitance of 0.300 pF, how far must the key be depressed before the circuitry detects its depression?
So what do you get for the initial capacitance?
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 21 ·
