Is the Electromagnetic Wave Equation Invariant Under Galilean Transformation?
The discussion revolves around the electromagnetic wave equation and its invariance under Galilean transformation. Participants are exploring the mathematical implications of the equation, particularly focusing on the differentiation process involved in transforming the variables.
  • Mathematical reasoning, Assumption checking
  • Participants are attempting to understand the steps involved in differentiating the electromagnetic wave equation under Galilean transformation. There is a specific focus on deriving terms related to the second time derivative and how they relate to the first derivatives.
Some participants are seeking clarification on the differentiation process, particularly regarding the derivation of specific terms in the context of the Galilean transformation. There is an ongoing exchange of ideas, with some guidance offered on the differentiation rules applicable to the problem.
Participants are working under the constraints of homework rules, which require them to show the non-invariance of the electromagnetic wave equation without providing complete solutions. The discussion reflects a collaborative effort to clarify mathematical reasoning and assumptions related to the problem.
Amith2006
1) Show that the electromagnetic wave equation,
d^2(phi)/dx^2 + d^2(phi)/dy^2 + d^2(phi)/dz^2 –(1/c^2)( d^2(phi)/dt^2) = 0
is not invariant under Galilean transformation.
Note: here d is a partial differential operator.
I have the solution but I couldn’t understand one particular step. The solution is as follows:
The equation will be invariant if it retains the same form when expressed in terms of the new variables x’,y’,z’,t’. From Galilean transformation we have,
dx’/dx=1, dx’/dt=-v, dt’/dt=dy’/dy=dz’/dz=1, dx’/dy= dx’/dz= dy’/dx= dt’/dx=0
From chain rule and using the above results we have,
d(phi)/dx= [d(phi)/dx’][dx’/dx] + [d(phi)/dy’][dy’/dx] + [d(phi)/dz’][dz’/dx] + d(phi)/dt’][dt’/dx] = d(phi)/dx’
And,
d^2(phi)/dx^2= d^2(phi)/dx’^2
Similarly,
d^2(phi)/dy^2= d^2(phi)/dy’^2 &
d^2(phi)/dz^2= d^2(phi)/dz’^2
Moreover,
d(phi)/dt= -v[d(phi)/dx’] + d(phi)/dt’
Differentiating the above equation with respect to t ,
d^2(phi)/dt^2 = d^2(phi)/dt’^2 -2v[d^2(phi)/dx’dt’] + v^2[d^2(phi)/dx’^2]
This is where I have a doubt. I differentiated in the following way:
d^2(phi)/dt^2= -v[d^2(phi)/dx’dt] - [d(phi)/dx’][dv/dt] + [d^2(phi)/dt’^2]
= -v[(d^2(phi)/dx’^2)(dx’/dt)] –[d(phi)/dx’][dv/dt] + [d^2(phi)/dt’^2]
= (v^2)[ d^2(phi)/dx’^2] –[d(phi)/dx’][dv/dt] + [d^2(phi)/dt’^2]
I am able derive 2 of the terms but how to derive the third term -2v[d^2(phi)/dx’dt’] from –[d(phi)/dx’][dv/dt]. Could somebody please help me with this derivation?
And,
Similarly,
Moreover,
That's incorrect. Recall that, as you already used for the first derivative,
[tex]\frac{d}{dt} (anything) = \frac{d}{dt'} (anything) -v \frac{d}{dx'}(anything)[/tex]
In addition, you may use that the derivative of "v" is zero (v is a constant in a Galilean transformation).
Apply what I just wrote above to the time deriavtive of your two terms appearing in d(phi)/dt= -v[d(phi)/dx’] + d(phi)/dt’ and you will get the answer.
Patrick
I didn't get your point. Could u please explain it in detail?
bump... have same question
  • · Replies 27 ·
