Data Acquisition Help with NI PCI-6025E and LabView
  • Thread starter Thread starter jamesrc
    Data
The discussion revolves around data acquisition using the National Instruments PCI-6025E board with LabView, focusing on issues related to resolution and input range configuration. Participants explore the implications of different settings on the data being recorded.
  • Homework-related
  • One participant notes a discrepancy in expected resolution when using the PCI-6025E board, calculating a theoretical resolution of 4.9 mV but observing steps of ~2.5 mV in the recorded data.
  • Another participant suggests that the issue may arise from the board being configured in single-ended mode, which could double the resolution, or possibly being set to a +/-5V range.
  • The original poster confirms that the board was indeed in single-ended mode, resolving the initial confusion about resolution.
  • The original poster then inquires about how the DAQ assistant wizard handles input ranges, questioning whether selecting a non-standard range (e.g., +/-9V) would function similarly to a standard range (e.g., +/-10V).
  • One participant expresses inability to answer the follow-up question but recommends contacting NI support for clarification on potential errors in their software.
Participants generally agree on the resolution issue being related to the configuration of the board. However, the follow-up question regarding the DAQ assistant wizard's handling of input ranges remains unresolved, with no consensus on the behavior of non-standard range selections.
The discussion does not clarify the specific behavior of the DAQ assistant wizard when non-standard ranges are selected, leaving assumptions about its functionality unaddressed.
This discussion may be useful for users of National Instruments data acquisition systems, particularly those working with the PCI-6025E board and LabView, as well as individuals seeking to understand configuration impacts on data resolution.
jamesrc
Hi,
I've got a little mental block with something I'm working on and was hoping someone could help out:
I'm doing some data acquisition with a National Instruments PCI-6025E board using LabView (not a lot of experience with LabView by the way). Anyway, the board is supposed to be a 12-bit board and the input range (for the analog inputs) is supposed to be -10 to +10 V. If I do the math, my resolution should be 20/(2^12) = 4.9 mV, right? Why, then, when I read data using the program does it appear that my resolution is twice that (I see steps in the data recording spaced ~2.5 mV apart). Any hints on what I'm doing wrong?
Thanks.
Any chance you have it configured in single-ended mode? That will double the resolution. Or maybe it's in +/-5V range mode?
Your math appears correct for the +/-10V range.
That was it - it's in single ended mode.
Thanks for the help.
While I've got you and since you mentioned range, do you happen to know how the ranging works when you're using the DAQ assistant wizard (I know, this is what I get for using a black box component). I mean, I think the board specs allow for +/-50mV to +/-10V ranges; if you enter in the range you are using, will it adjust accordingly? What if you choose a range that isn't one of the board selectable ranges? Like if I enter +/-9V (not that I planned to) will it behave the same as if it were +/-10V? Thanks again.
Glad to help. I'm not of any help on your follow-up question unfortunately. But NI has pretty good support, so you should be able to just give them a call on Monday to ask about what kind of errors get thrown by the different parts of their software.
OK. Thanks again.
