Multipole Expansion Homework: Calculate Approx. Electrostatic Potential
The discussion focuses on calculating the approximate electrostatic potential for a system of three charges: +q at (0,0,a), -q at (0,a,0), and (0,-a,0). The participant is tasked with using the multipole expansion method, specifically the formula V(r) = (1/4πE₀)Σ(1/(r^(n+1)))∫(r')^nPₙcos(θ)ρ(r')dr', but expresses confusion regarding the necessity of this approach given the non-zero total charge. The participant concludes that the potential should be expressed as a sum of individual charge contributions, indicating a misunderstanding of the multipole expansion's application in this scenario.
  • Understanding of electrostatics and charge distributions
  • Familiarity with multipole expansion techniques
  • Knowledge of spherical coordinates and their application in physics
  • Proficiency in integral calculus, particularly in evaluating potentials
  • Study the principles of multipole expansion in electrostatics
  • Learn how to derive the electrostatic potential from point charge distributions
  • Explore the implications of charge neutrality in multipole expansions
  • Practice calculating potentials using spherical coordinates in various charge configurations
Students and professionals in physics, particularly those focusing on electrostatics, as well as educators looking to clarify the application of multipole expansions in complex charge arrangements.
Ruddiger27
I have to calculate the approximate electrostatic potential far from the origin for the following arrangement of three charges: +q at (0,0,a), -q at (0,a,0) and (0,-a,0). I have to give the final answer in spherical coordinates and keep the first two non-zero terms in the multipole expansion.
So the equation for the multipole expansion is:
V(r) = (1/4piEo)SUM(1/(r^(n+1)))*int(r')^n*Pn*cos(theta)*pho(r')dr'
My main problem here is that I don't see the need for a multipole expansion, since we're taking the measurement far from the origin the charges will appear as a point charge. Also I'm pretty sure the total charge has to be zero to use the multipole expansion, but the total charge isn't zero here.
What I've got is a triangle on the z-y axes, with a point on the x-axis where I'm measuring the potential. I've got
V(x,y,z)= (1/4*piEo)(q/L - q/D - q/S), where L, D and S are the distances from the charges to the point of observation, and I've drawn them such that L=D=S= sqrt(a^2 + x^2)
This doesn't really work, since two of the charges cancel out and leave one of the negative charges as the sole contributor to the potential. Also I think I've missed the point of the question by placing the point of observation on the x-axis.
I think I should rewrite the integral for the potential for the multipole expansion as a point charge distribution, but I'm not sure how to go about that.
First of all, write the poential as a sum of potentials due to the individual charges for a general point in space, then write the resulting potential terms in an expansion like you alluded to.
Thanks for that.
