Tried U-sub and anti-differentiation
  • Thread starter Thread starter clipzfan611
The discussion revolves around evaluating the integral \(2\pi \int_0^8 \left(\frac{y^5}{64}- y^2\right)dy\), which involves concepts from calculus, specifically integration and the method of shells for volume calculation.
  • Participants explore the use of substitution and anti-differentiation, with some suggesting splitting the integral into two parts. Questions arise regarding the correctness of computed integrals and the implications of definite versus indefinite integrals.
There is an ongoing exploration of the correct approach to evaluating the integral, with some participants providing guidance on handling constants and the limits of integration. Multiple interpretations of the problem are being discussed, particularly concerning the order of functions in the integral.
Participants note the potential confusion regarding the negative result of the volume calculation and the need to consider the order of the functions being integrated. There is mention of the functions intersecting, which affects the setup of the integral.
clipzfan611
[tex]2\pi \int_0^8 (\frac{y^5}{64}- y^2)dy[/tex]
Tried U-sub and anti-differentiation and none of them got the answer it should be. Help?
You don't need a substitution; remember that this can be split into two integrals [tex]2\pi\left[\int_0^8\frac{1}{64}y^5 dy-\int_0^8y^2 dy\right][/tex].
Can you evaluate these integrals?
Yeah I got 6/64y^6 for the first part. Is that right?
No, it should not have a y in it.
As the previous post points out, this is a definite integral and so should not contain y.
But, still, you have computed the indefinite integral incorrectly. Recall: [tex]\int y^ndy=\frac{y^{(n+1)}}{n+1}[/tex]
This is a shells problem with respect to y. I know y^5 would come out to 1/6y^6 but the 1/64 thing is confusing me.
Edit: Oh you multiply 1/6 and 1/64?
Well, 1/64 is a constant, and so can be taken out of the integral. I could've done this above to give [tex]\frac{1}{64}\int y^5dy[/tex] Since you know what the value of [tex]\int y^5dy[/tex] is, then simply multiply this by 1/64. Then, you need to use the limits of integration.
I got the answer--it is -64pi/3. OT: However, can you have a negative volume in the first quadrant? Because I graphed the original equations y=x and y=64x^1/4. Thanks for your help.
The reason your answer is negative is because you got the order wrong. You wanted the larger, higher valued functions area, minus the smaller ones. You will see for values from 0 to 8, your bounds of integration, the y^5/64 may be smaller than the y^2, and may be larger. So you must split up the integral where the functions intersect.
They look like they intersect at 4, let's say 4 for the sake of simplicity, when you do it, you have to solve [tex]\frac{y^5}{64}=y^2[/tex], you can get that into a simple cubic. I am pretty sure its 4 though.
Before 4, y^2 is larger, so the area here is [tex]\int_0^{4} y^2 - \frac{y^5}{64} dy[/tex], after 4 the area is [tex]\int_4^8 \frac{y^5}{64} - y^2 dy[/tex]...
EDIT: For the washers problem, multiply this result by 2 pi as required.
Oop! I recognize that integral. clipzfan66 posted a "volume of revolution" problem in another thread and I suggested that order of integration. I was thinking about x to a power larger than 1 and that y= xn was less than y= x for x< 1! Didn't think about this being a fractional power!
  • · Replies 34 ·
  • · Replies 27 ·
