Electric Potential and Forces in Spherical Raindrop Interactions
The discussion revolves around the electric potential and forces related to spherical raindrops with a given charge and potential. The original poster presents a problem involving the calculation of the radius of a charged raindrop, the force between two such raindrops, and the potential of a combined raindrop.
  • The original poster considers treating the raindrop as a point charge and integrating the electric field to find the radius. They question the validity of this approach and whether it can be applied to calculate the repelling force between two raindrops.
  • Some participants suggest treating the raindrop as having a uniform charge density and integrating over the sphere's volume instead of assuming a point charge.
  • There is a discussion about the potential of the new combined raindrop and whether the approach of integrating the electric field from the old radius to the new radius is appropriate.
  • One participant questions the correctness of the original poster's integration setup for calculating the potential.
The discussion is active, with participants providing alternative approaches and questioning the assumptions made by the original poster. Some guidance has been offered regarding the treatment of the raindrop's charge distribution and the application of Gauss's Law, but no consensus has been reached on the methods to be used.
Participants are navigating the complexities of electric potential and forces in the context of spherical charge distributions, with some uncertainty about the assumptions regarding charge distribution and the methods of integration. There is also mention of homework rules that may limit the types of solutions discussed.
broegger
i'm having trouble with this:
A spherical raindrop has a charge Q = 3*10^-11. The potential at the surface is V = 500 V (V = 0 infinitely far away).
a) Determine the radius of the drop.
My first thought was to consider the raindrop as a point charge and then integrate the electric field from this point charge from a distance that equals the unknown radius R to infinity and, finally, equate this to 500 V.. but I'm not sure how to do this or if it's even right...
Another, identical, raindrop is brought in touch with the first one.
b) Determine the magnitude of the repelling force between the raindrops just before they touch each other.
Here, again, I would consider the drops as point charges and then calculate the Coulomb force when the distance between them equals 2R. Can you do that even though the charge distribution is in reality homogenous?
The two raindrops is now brought together and forms a single, spherical raindrop.
c) What is the potential at the surface of this new raindrop?
Here I would integrate the electric field from the 'old' radius to the radius of the new drop and then subtract this from the 500 V.. Again, I have no idea if you can do that...
I would not assume a point charge. Treat it, rather, as a uniform charge density. That is, since the volume of the sphere is (4/3)πR3, the charge density is (4Q)/(3πR3) and the electric force at distance r from the center is (4Q)/(3πR3r2) Integrate that over the sphere of radius R:
[tex]\frac{4Q}{3\piR^3}\int_{r=0}^R\int_{\theta=0}^{2\pi}\int_{\phi=0}^{\pi}(\frac{1}{r^2})(r^2 sin(\phi)d\phi d\theta dr[/tex]
(If you have a formula for the field due to a homogeneous sphere of charge at a point insidethe sphere, you can use that instead)
Set that equal to 500V and solve for R.
Yes. As long as you are outside a homogeneous sphere, you can treat
the sphere as a point charge
[/b]The two raindrops is now brought together and forms a single, spherical raindrop.
Here I would integrate the electric field from the 'old' radius to the radius of the new drop and then subtract this from the 500 V.. Again, I have no idea if you can do that... [/B]
That's not the way I would do it. You can assume that the new drop has twice the volume and twice the charge of the old sphere.
Use V= (4/3)πR3 to determine the radius of the new sphere (it's not twice the radius!) and integrate the force function to find the field. (or, if you have it, use the formula.)
Thanks for answering.
a) You mean solving this equation
[tex]\int_{R}^{\infty} \mathbf{\vec{E}} \bullet d\mathbf{\vec{r}} = \int_{R}^{\infty} \frac{1}{4\pi{}\epsilon_{0}} \frac{Q}{r^2} dr = 500 V[/tex]
with respect to R is wrong. If so, why?
Use Gauss Law to find C = 4 * pi * e0 * R
and of course q = CV
  • · Replies 22 ·
  • · Replies 17 ·
