Electric Field and the weight of an electron
The discussion revolves around determining the magnitude and direction of the electric field required to balance the weight of an electron and a proton. Participants explore the relationship between electric fields and gravitational forces, particularly focusing on the implications of charge signs and field directions.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the formula for electric field strength and question how to determine the direction of the electric field in relation to the gravitational force acting on charged particles. There is exploration of how the sign of the charge affects the direction of the electric field and the forces involved.
The discussion is ongoing, with participants raising questions about the nature of electric fields and their interactions with charged particles. Some guidance has been provided regarding the relationship between the direction of the electric field and the gravitational force, but no consensus has been reached on the specifics of the directionality or the overall setup.
Participants note the lack of specific information about the electric field in the original question, which may affect the clarity of the discussion. There is also mention of the need to consider the source charge when determining the electric field's direction.
brunie
What is the magnitude and direction of the electric field to balance the weight of an electron, a proton?
well electric field = F / q
so the force is gravity and the charge is the charge on each
so E = (mass of electron * 9.8) / charge on electron
similarly for proton
but how do i kno the direction??
electron is negative
proton is positive
would the field have to be in same direction (from equation) or in the opposite direction to balance the forces??
The direction depends on the source charge. For an electron and positive field, for example, you'll have to place the electron at a suitable distance between the Earth and source charge so that both forces cancel.
but the electric field needs to balance off the electron/proton
how does the sign on the field work?
ie. is it same/opposite as sign of charge
No information about the field has been provided in your question. Is this part of larger question? Remember, field lines of a positive charge "spread out" while those of negative charge converge. And a positive charge always tends to move along the direction of field.
that is why i am confused, the question is the same as posted and the direction can either be up, down, left, right, in, or out
but i didnt think the direction would be constant for the entire field
Well, the only answer one can possibly give, with the information provided, is that it is opposite to the direction of the gravitational field at the point.
No need to worry about source charges. For this problem, all you care about is the direction of the field at the location of the particle.
To balance the weight of the particle, which always points down, the electric force must point up. To get an upward force, which direction does the field have to point?
Hint: A positive charge in an electric field will experience an electric force in the same direction as the field.
