Help with Strange Reaction on He-4
  • Thread starter Thread starter vanesch
    Reaction Strange
The discussion revolves around the thermal neutron reactions involving Helium-4 (He-4), specifically the reaction denoted as He-4(N,P)H,SIG. Participants are examining the validity of tabulated cross-section data for this reaction and its implications for using He-4 in neutron detection applications.
  • Experimental/applied
  • One participant questions the energetics of the reaction, suggesting that the calculated energy balance indicates it may not be possible, and speculates about potential He-3 contamination in the He-4 sample.
  • Another participant argues that He-4 has a low cross-section for neutron absorption, suggesting that it is more likely to scatter rather than absorb a neutron, and proposes an alternative reaction involving tritium (T) and a neutron.
  • A participant expresses concern about the implications of the He-4 cross-section for thermal neutrons on their experimental setup, indicating that it complicates the use of He-4 as a substitute for He-3 in neutron detection.
  • One participant shares their experience with neutron detection and discusses methods to discriminate against thermal neutrons, mentioning the use of Gadolinium and water in their experimental setup.
  • Another participant provides links to data sources and expresses increasing skepticism about the accuracy of the tabulated cross-section data for the He-4 reaction.
  • Several participants emphasize the difficulty in finding reactions that conserve energy when considering thermal neutrons interacting with He-4, suggesting that elastic scattering may be the only viable process.
Participants express differing views on the feasibility of the He-4(N,P)H,SIG reaction, with some questioning its validity based on energy conservation and cross-section data, while others propose alternative reactions. There is no consensus on the accuracy of the data or the implications for neutron detection.
Participants note limitations in the available data and the complexity of neutron interactions with He-4, including potential contamination and the need for precise background measurements in experimental setups.
vanesch
Staff Emeritus
Hello,
can anybody help me out with the following (IMO) strange reaction:
HE-4(N,P)H,SIG
I'm looking for the thermal neutron reactions on He-4, and according to this site:
http://www3.nndc.bnl.gov/exfor7/endf00.htm
(enter target He-4, reaction n)
the above reaction has a tabulated cross section well into the thermal and cold domain (~10^(-2) barn and up). The Q-factor for this reaction is something like 801 KeV.
However, when I try to calculate the energetic balance, using the values given by
http://www3.nndc.bnl.gov/nudat2/reCenter.jsp?z=1&n=2
then this doesn't make any sense:
neutron: Delta = 8.0713 MeV
He-4: Delta = 2.4249 MeV
proton: Delta = 7.289 MeV
neutron + He-4 - proton = 3.2072 MeV
and nothing containing a proton has such a low energy content, so this reaction is energetically not possible IMO.
I suspect a He-3 contamination in the He-4 when these data were taken, but am I totally off and is this reaction real ?
I don't see this reaction as possible.
He-4 has a low cross-section, and it is more likely to scatter, than absorb a neutron. I tried a Q-calc with n and He-4, but it kept giving me n and H-4.
I don't think n + He-4 -> H-4 + p is feasible, but
n + He4 -> T + n' + p might be possible, but I believe that requires some threshold energy.
He-3 certainly loves neutrons.
The point is: I wanted to use He-4 as a replacement for He-3 in a thermal neutron detector to find out what is the background of non-thermal neutron counts. But if there is a (small) cross section of He-4 for thermal neutrons, this screws me. Moreover the Q is comparable to the He-3 reaction, so I wouldn't be able to discriminate against it.
This is why it annoyed me to find this tabulated cross section for He-4 (n,p) on the NNDC site. So do you think it is an error in their data tables ?
I looked for information on n,p reactions for He-4 and could not find anything. What I did find it this -
http://www3.nndc.bnl.gov/exfor7/servlet/E4sGetEvaluation?EvalID=16316&req=4999
The cross section for n-absorption by He-4 is small (0.05 barn) for thermal neutrons, and I believe that is for n,g, although the above link has a statement - "THERE ARE NO GAMMA IN NEUTRON INTERACTION WITH HE-4 NUCLEI". The cross-sections for n,g by Kr and Xe are approximately 24 b for thermal neutrons.
What neutron spectrum are you investigating? Thermal + epithermal?
To discriminate from thermal neutrons, in the past I have used a box covered in Gadolinium which absorbed the thermal neutrons but allowed higher energy neutrons to enter. The box was filled with water and my colleagues and I used small buttons of Cd to activate by the epithermal neutrons slowing down to thermal energies in the water. It was a crude experiment.
The data I'm talking about is here:
http://www3.nndc.bnl.gov/exfor7/servlet/E4sGetIntSection?SectID=304113&req=5007
I'm now more and more convinced that this is erroneous.
(you can find the file by going to the http://www.nndc.bnl.gov/exfor7/endf00.htm
page, and filling in:
target 4He
reaction n,p
and submitting.
You then ask for "reactions" and you get said data.
The problem is that we have to establish extremely low backgrounds in a flux of thermal neutrons (requirements of less than 1 count per minute on an area of > 3m^2 in a flux of thermal neutrons that can go up to 10^6/second - simply crazy requirements). Now, there are of course also cosmic neutrons, an entire gamma spectrum, epithermal and other at that low level. The "trick" I wanted to use was to fill the detector with He-4 instead of He-3, because as such, I am sure that I ONLY see non-thermal neutrons and other stuff. In other words, I'm sure I have a pure background measurement in real conditions of use.
But if there is a reaction with thermal neutrons in He-4, then this trick won't work, because my main "background" will be in fact a signal.
The point is that I don't seem to find any reaction n(thermal) + He-4 -> anything that can respect conservation of energy (except for elastic scattering).
I believe that is correct.
13K
14K
