Thread Closed
splitting fields again
Share Thread Thread Tools
Mar16-07, 01:56 PM   #1
Find the degree of the splitting field of the following:
[tex]x^6+x^3+1[/tex]
2. Relevant equations
3. The attempt at a solution
Can I do this?
Let [tex]y=x^3[/tex]
then
[tex]y^2+y+1[/tex]
has degree 2 over Q (From another problem)
So the degree of the splitting field is 2.
Or do I need to factor it out?
or do I need to look at the roots of the origional polynomial?
The method here is what I am confused about.
Thanks
CC
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar16-07, 02:26 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by happyg1 View Post
Can I ask two questions: do you think it is reasonable to write down a splitting field without reference to the original polynomial? Or how about this extreme example: x^n-1, let's set y=x^n, so we have y-1, and that splits over Q. Do you think what I did is reasonable?
Mar16-07, 07:50 PM   #3
OK
So I see that you can't do that with the x^n-1 polynomial. So what is the proper method? Factor? Use the TI89 to see what the roots are and then decide what to extend the field to? Is it not possible to reduce the polynomial somehow?....????
I just don't know HOW to do these problems. So far it's just been trial and error for me. I'm not seeing a method.
Please tell me the WAY to approach this.
CC
Mar16-07, 08:01 PM   #4
I just don't know how to approach this type of problem at all.
I need steps to follow..or things to try. I got confused about this the first time we went over it and since then I'm even more lost.
Prof says that if you have x^4+x^2+1 it can be reduced by letting y=x^2.
Then you get y^2+y+1. Degree of splitting field is 2. Is that a special case?
CC
Mar16-07, 08:43 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
CC
It's too early to think about algorithms, methinks -- you need to think carefully about the individual steps.
Let's consider your professor's example. He wants to form the splitting field E of y^2 + y + 1. Well, you know the quadratic case well (right?), so you know exactly what happens.
So, you have a field extension Q --> E.
Does E contain the roots of x^4 + x^2 + 1? How might you tell? If you can't think of a "good" way, can you think of a "dumb" way?
Don't read on until you can answer that question. I've colored it white so you don't do it by accident -- but you can still read it later by highlighting the text.
Okay, so you've figured out that E is not the splitting field of x^4 + x^2 + 1. Maybe you did it by linear algebra (plug an arbitrary element of E into the polynomial, and show the system of linear equations has no solution), or maybe you had a better way.
So the next question is: is E even relevant? You are looking for the splitting field F of x^4 + x^2 + 1 -- that is, the smallest field extension:
Q --> F
Knowing E is really helpful if we have the tower of extensions
Q --> E --> F.
(Well, if this is not true, there still may be a way for E to be useful. But if there is, that's not what I'm talking about)
So your next task is to figure out if E a subfield of F -- that is, if F contains the roots of x^4 + x^2 + 1, does it also contain the roots of y^2 + y + 1?
Mar18-07, 10:24 AM   #6
OK
What i did was just solve for the roots on the calculator to see what they are.
I got [tex]\pm\frac{1\pm\sqrt3}{2}i[/tex]for x^4+x^2+1
and I got [tex]\frac{-1\pm\sqrt3}{2}i[/tex]forx^2+x+1
So looking at these to sets of roots,I think that the splitting field is [tex]Q(\sqrt3,i)[/tex] Which would have degree 4 over Q, not 2.
So now I'm even MORE confused. Is it 2 or 4?
My prof did this:
let w be some root of p(x)=x^4+x^2+1
then
[tex]w^4+w^2+1=0[/tex]
[tex](-w)^4+(-w)^2+1=0[/tex]
[tex]w^4=-w^2-1[/tex]
[tex]w^6=-w^4-w^2=1[/tex]
[tex]w^8=w^2[/tex]
[tex](w^2)^4+(w^2)^2+1=w^8+w^4+1=w^2+w^4+1=0[/tex]
so then [tex]w^2, -w^2[/tex] are roots.
So the splitting field is Q(w). The degree of this is either 4 or 2.
So then:
[tex]x^4+x^2+1=(x^4+2x^2+1)-2x=(x^2+1)-x^2=(x^2-x+1)(x^2+x+1)[/tex]
So our degree [Q(w):Q]=2
I don't understand why he did the substitutions, really. I guess it's only valid for this particular one.
Then he said we could just plug in y=x^2 and get the same thing.
SO
the splitting field is of degree 2 even though it has i and [tex]\sqrt3[/tex] in it.
I did another problem with [tex]Q(\sqrt3,i)[/tex](That one was x^6+1) and the degree there was 4?
I just don't get this.
CC
Mar18-07, 11:03 AM   #7
Recognitions:
OK
Why did you leap to deciding that the splitting field was Q[sqrt(3),i]? Certainly the splitting field is contained in that, and is the smallest subfield of Q[sqrt(3),i] that contains the roots above, but it does not immediately follow that it is all of it. (It may or may not be, and looking through some of the stuff in this thread, I think at least one person has made a mistake about this question).
Mar19-07, 10:56 AM   #8
OK
Here are my thoughts on the [tex]x^4+x^2+1[/tex] problem.
[tex]Q(\sqrt3,i)[/tex] isn't the smallest field because all of the roots are complex, so I DON'T need [tex]\sqrt3[/tex] in there. And [Q(i):Q]=2.
Now I have this:Find the splitting field of [tex]x^4-2[/tex].
So this irreducible over Q of degree 4,with a real root. I also need i in my splitting field. So I have [tex][Q(x^4-2):Q][Q(i):Q]=4*2=8[/tex]
Back to [tex]x^6+x^3+1[/tex]
This has all complex roots, so I need to extend my rationals to i again.
So it has degree 2?
I'm not sure if I need to try to factor it into 3 quadratics...
EDIT:I think that this last poly is irreducible over Q. So the degree is 6? Do I need to put i in there too?
Am I closer?
CC
Mar19-07, 11:08 AM   #9
Recognitions:
Quote by matt grime View Post
I think at least one person has made a mistake about this question.
I made two. I assumed the polynomial was irreducible, and misremembered how much effort it was to test for irreducibility over E by plugging in an arbitrary element. (I mentally mixed it up with the "find the minimal polynomial of this number" problem) And I should have known better anyways, since it's clear that the roots of x^4 + x^2 + 1 are sixth roots of unity.
Mar19-07, 11:10 AM   #10
Recognitions:
OK
The roots of x^4 + x^2 + 1 are obvously not in Q(i)... are you sure you need i?
Mar19-07, 11:31 AM   #11
OK,
the reason I thought I needed i was because all of the roots are complex.
And I guess I'm still confused about the whole splitting field thing. i don't know what the splitting field IS. It looks to me like the x^4+x^2+1 wouldn't split over the rationals because the roots are complex.
Am I supposed to be looking only at the degree of the irreducible factors over Q?
I'm re-lost. I thought I was making progress...but I'm still back where I started.
What do you think about the other ones I wrote down?
Thanks
CC
Mar19-07, 12:21 PM   #12
Recognitions:
There are complex extensions of Q that do not contain i. This is one of them.
Exercise: prove that [itex]i \notin \mathbb{Q}(i \sqrt{2}).[/itex]
By explicit computation, you found that the roots of f(x) = x^4 + x^2 + 1 are [itex](\pm 1 \pm i \sqrt{3}) / 2[/itex]. (I assume this is what you meant)
Therefore, by its very definition, the splitting field E of f over Q is
[tex]
E = \mathbb{Q}\left( \frac{1 + i \sqrt{3}}{2}, \frac{1 - i \sqrt{3}}{2}, \frac{-1 + i \sqrt{3}}{2}, \frac{-1 - i \sqrt{3}}{2} \right)
[/tex]
We can clearly see that
[tex]E \subseteq \mathbb{Q}( \sqrt{3}, i),[/tex]
but it's not so clear if that should be an equality. Do you have an idea how you might try to prove they are equal? How to prove they are unequal?
From our comments, you can probably guess that they are not equal. Also, as you observed, E is clearly not equal to Q. So, we have this (strict) tower of field extensions:
[tex]\mathbb{Q} \subset E \subset \mathbb{Q}(\sqrt{3}, i)[/tex]
You know the degree [itex][\mathbb{Q}(\sqrt{3}, i) : \mathbb{Q}] = 4[/itex], right? (How do you know that?) Do you see how that immediately tells you the degree [E:Q], without actually having to compute E? And also how it gives us an immediate way to simplify the presentation of E?
But that's no fun, let's keep looking at the problem. How did you know that [itex][\mathbb{Q}(\sqrt{3}, i) : \mathbb{Q}] = 4[/itex]? What method did you use? Will that work for E?
(Incidentally, IMHO, the simplest way of all is to notice that the roots are sixth roots of unity, which makes it easy to find a z so that E = Q(z). Galois theory makes it even easier to compute the degree)
Mar19-07, 12:33 PM   #13
[tex][Q(i):Q][Q(\sqrt3):Q]=2*2=4[/tex] and E has to be less than 4, so it has to be 2? Looking at the tower above. We haven't gotten to the galois stuff quite yet.
I have a mental block on how a complex extension doesn't have i in it. I can't see it.
Are my other ones even close?
CC
Mar19-07, 01:07 PM   #14
Recognitions:
Why would
[tex][\mathbb{Q}(\sqrt{3}, i) : \mathbb{Q}] = [\matbb{Q}(i) : \matbb{Q}] [\matbb{Q}(\sqrt{3}) : \matbb{Q}][/tex]
be true? The theorem you learned about the degre of field extensions says, for example,
[tex][\mathbb{Q}(\sqrt{3}, i) : \mathbb{Q}] = [\matbb{Q}(\sqrt{3}, i) : \matbb{Q}(i)] [\matbb{Q}(i) : \matbb{Q}][/tex]
when applied to the chain [itex]\mathbb{Q} \subseteq \mathbb{Q}(i) \subseteq \mathbb{Q}(i, \sqrt{3})[/itex]. The equation you wrote is simply a coincidence.
Consider this example: what is the degree
[tex][ \mathbb{Q}(i, i + 1) : \mathbb{Q} ]?[/tex]
Well, I gave you a specific example of a complex extension that does not contain i. What sort of numbers does [itex]\mathbb{Q}(i \sqrt{2})[/itex] contain? You should be able to write this field explicitly as a set. (or as a vector space over Q)
Mar19-07, 04:51 PM   #15
I re-read the theorem and I see your point about my wrongness.
A basis for this
is [tex](1,i\sqrt2)[/tex]?
so the degree is 2?
And the degree of
[tex][ \mathbb{Q}(i, i + 1) : \mathbb{Q} ][/tex]
is also 2?
and what I need in my problem x^4+x^2+1 is the degree of [tex]i\sqrt3[/tex]
So here's another question:
If I can find the minimal polynomial, does that help me at all?
Is the degree of the minimal polynomial the degree of the splitting field?
I'm so confused about this
Any good links to look at?
I can't apply what we did in class to this.
HELP
PS I just went and spoke to my prof and I am even MORE lost.
Mar19-07, 05:22 PM   #16
Recognitions:
Minimal polynomials can help for problems: if you have a field extension F(a)/F, then the degree of the minimal polynomial of a over F is [F(a):F].
The minimal polynomial of [itex]\sqrt{3}[/itex] over [itex]\mathbb{Q}(i)[/itex] is (x^2 - 3), so [itex][\mathbb{Q}(i, \sqrt{3}) : \mathbb{Q}(i)] = 2[/itex]. But the minimal polynomial of (i + 1) over [itex]\mathbb{Q}(i)[/itex] is (x - i - 1). So, [itex][\mathbb{Q}(i, i+1) : \mathbb{Q}(i)] = 1[/itex].
If your plan is to find the degree of a field extension by adjoining one root at a time, then you could use minimal polynomials to find the degree of each step.
You know that the splitting field of f(x) = x^4 + x^2 + 1 is contained in [itex]\mathbb{Q}(i \sqrt{3})[/itex]. Can you prove that [itex]i \sqrt{3}[/itex] is contained in the splitting field of f? If so, then [itex]\mathbb{Q}(i \sqrt{3})[/itex] is, in fact, the splitting field of f. And, now that you have a primitive generator for that field, you can find its degree with a minimal polynomial.
Mar19-07, 06:55 PM   #17
but isn't [Q(i):Q]=2? so [Q(i,i+1):Q(i)][Q(i):Q]=2?
I understand the minimal polynomial thing, I think.
I will conyinue to stare at this some more later.
Thanks
CC
Thread Closed
Thread Tools
Similar Threads for: splitting fields again
Thread Forum Replies
Zeeman Splitting Atomic, Solid State, Comp. Physics 2
Splitting fields Calculus & Beyond Homework 4
splitting fields Calculus & Beyond Homework 4
Uniqueness of Splitting Fields Linear & Abstract Algebra 5
H-NMR splitting Chemistry 2
