Optoisolation: Why Do You Need It?
  • Thread starter Thread starter louie
Optoisolation is essential for preventing current from one part of a circuit from affecting another, particularly when interfacing high-voltage and low-voltage components. It is commonly employed in scenarios where different voltage supplies are utilized, such as +/- 15 V for logic circuits and 30 V for drive circuitry. This technique also facilitates a "floating ground," allowing independent grounding of circuit sections while maintaining communication.
  • Understanding of optoisolators and their function in circuit design
  • Knowledge of voltage levels in electronic circuits
  • Familiarity with grounding techniques in electrical engineering
  • Basic principles of electrical isolation in circuit design
  • Research the different types of optoisolators and their applications
  • Learn about designing circuits with floating grounds
  • Explore the impact of voltage differences on circuit performance
  • Study safety standards related to high-voltage and low-voltage circuit integration
Electrical engineers, circuit designers, and anyone involved in the development of systems requiring safe interfacing between high and low voltage components.
louie
Do you really only use electrical isolation between logic level control signals and the drive circuits (ie. dc-dc converter). Is the main reason for this because different voltage supplies are used (example: +/- 15 V for logic and 30 V for drive circuitry) and each has it's own reference to ground, so you don't want to short anything out.
Can someone please explain this a little better to me
Thanks
Opto-isolation is used whenever you don't want current from one part of a circuit to flow through another part of the circuit. It's mainly used when you have a portion of a circuit which uses large voltages, and another which uses low voltages. It can also be used to provide a "floating ground," so that two parts of a circuit can be grounded independently, yet still communicate.
- Warren
  • · Replies 21 ·
9K
  • · Replies 47 ·
  • · Replies 20 ·
