How Do You Calculate Voltage, Power, and Current in a Combination Circuit?
The discussion revolves around calculating voltage, power, and current in a combination circuit, with a specific focus on the behavior of multiple bulbs connected in series and parallel configurations. The original poster provides a circuit diagram and seeks assistance in determining the total voltage, resistance, power, and current for each bulb.
  • Participants discuss the configuration of the circuit, with some expressing uncertainty about which components are in series or parallel. There are attempts to calculate total resistance and current, with various values being proposed for individual bulbs.
Some participants have provided calculations for total current and resistance, while others are questioning the correctness of their findings. There is an ongoing exploration of the values for each bulb, with no explicit consensus on the accuracy of the results yet.
Participants note a potential misunderstanding regarding the units of resistance, as well as the need for clarification on the circuit diagram. There is also mention of a typing error that may have affected the calculations.
jenita
here is the new diagram of combination...The voltage is 120 and its asking me to find total voltage, resistance, power and current. The resistance is given, its all 3 its asking for voltage, power and current for each bulb///please help me...thanks a looot and the picture for this problem is down please click com.jpg...thanks a loot...
jenita said:
oops sorry the power battery should be at the bottom in the middle sorry about that if u want me to send u another diagram i will...and i don't no which one is parralel and series...when i combined i got the total resistance of 2.25 A... i did 9-1 + 3-1= 2.25 A. i will send u another
Resistance is not expressed in Amperes (A), it is expressed in Ohms ([tex]\Omega[/tex]).
You have found the correct value for the total resistance. So, what do you think you can find now knowing that?
ooops sorry about the expressed...typing mistake...after that i got current 53.333
i got total current 53.333 and i have to find for each bulb now
and by the way R1 is the left one, R2 is the top middle one, R3 is the right one and R4 is the top center of the power...for R4 i got 40 A and 120 V since its parallel...for R1, R2, and R3 i got 13.33A and for their voltage i got 39.99 V for each of them...i am not sure if that is right or not...
That sounds reasonable to me.
Thank U Sooo Muccccccccccch
