What Is the Radius of a Banked Turn in Airplane Flight?
  • Thread starter Thread starter cristina
The problem involves an airplane flying in a horizontal circle at a speed of 480 km/hr, with the wings banked at a 40-degree angle. The original poster is seeking to determine the radius of the circular path, expressing frustration over the lack of mention of radius in their coursework. The context suggests a focus on motion along a curved path.
  • Participants discuss drawing free body diagrams to analyze the forces acting on the airplane, including lift and weight. They explore the relationship between lift components and centripetal acceleration, raising questions about which method to use for solving the problem. There is also a discussion about applying similar reasoning to a different problem involving a stone on a string.
The discussion is active, with participants providing insights into the forces involved and equations that may be relevant. Some guidance has been offered regarding the use of equations and the importance of drawing diagrams, but there is no explicit consensus on a single approach to the original problem.
Participants mention the challenge posed by the professor's assignments and the potential confusion arising from different methods being discussed. There is also a note about the original poster's difficulty in applying the discussed methods to a related problem.
cristina
Not sure under what subject to name it
An airplane is flying in a horizontal circle at a speed of 480km/hr. banked for this turn; the wings of the plane are tilted to an angle of 40 degree from the horizontal. Assume that a lift force acting perpendicular to the wings holds the aircraft in the sky. What is the radius of the circle in which the plane is flying?
In the entier Newton chapter they never mention anything about radius.
Our professor always like to include one very difficult exercice in each assignment, for he doesn't believe in full mark! Isn't sweet?
A friend of mine sais its about Motion along a curved path?!
Would you pleaaase help me [b(]
This problem is a little tricky, but nothing to get too worried about. With most problems, a good first step is to draw out the problem (esp. a free body diagram). Look at the plane at a snapshot in time and try to see the forces that are acting on it. The "Lift," as stated in the problem is pointing perpendicular to the wings, which themselves are at 40 degrees. So you have a component of the lift pointing up (positive y-direction) and a component of the lift pointing toward the origin (in the -x direction as I've drawn mine). What other forces do we have? Well, we've got the weight of the airplane pointing straight down.
Now let's talk about the motion of the plane. The airplane is moving in a "horizontal" circle, so it's not moving up or down. So, we triumphantly write:
[tex]\Sigma F_y = L\cos\theta - mg = 0[/tex]
where L is the lift force, θ is 40 degrees, and m is the mass of the plane. That's one equation to work with.
Now we deal with the horizontal circular motion. Surely you've covered centripetal acceleration in class, right? If so, this equation should make a lot of sense:
[tex]\Sigma F_x = m\frac{v^2}R = L\sin\theta[/tex]
There's 2 equations and 2 unknowns (L and R; the unknown mass m conveniently drops out of the equations). All that's left for you to do is the algebra it takes to eliminate L and solve for R, the radius of the circle the plane is flying in. (Added reminder: watch your units.)
Centripetal acceleration:
[tex]a_c = \frac{v^2}{r}[/tex]
This centripetal acceleration is provided by the horizontal component of the lift, which you can calculate based on the given information. v is known, so the only variable left is r. Solve for r.
cookiemonster
which method to use the first or the second?
They're the same. jamesrc just posted before I did.
cookiemonster
Ok, may you please tell me why it doesn't work when I use your method to solve this?
A 0.20kg stone attached to a 0.8m string is rotated in the horizontal plane. The string makes an angle of 20 degree with the horizontal. Determine the speed of the stone.
I can't tell you unless you show me your work. If you follow jamesrc's method, though, you'll go right through the equation I put (it'll be your last equation). So if you tried his method and it worked and then you tried my method and it didn't, you just made a mistake somewhere the second time around.
As for your second problem, just use the equations we gave you and solve for v this time instead of r.
cookiemonster
I don't know how to use the characters you write with!
Am I on the write track to solve the new exercice using your equation?
because I feel there is something I'm missing. I will post it using regular character. please help me!
There are three forces acting on the stone. Gravity is acting straight downard. Centripetal acceleration is acting outward (i.e. away from the center of the circle that the stone's going in). The tension force is acting inward and 20 degrees up. All of these forces must balance.
So we have two vertical forces: gravity going downward and the vertical component of tension going upward. Write the equation for the vertical forces and calculate the force of tension from this.
Then you have two horizontal forces: the horizontal component of tension going inward and the centripetal force given by
[tex]F_c = m\frac{v^2}{r}[/tex]
(notice that this is F = ma, where a is the a I gave you in my first post).
Use this equation to calculate velocity after you've determined tension from the first equation.
Also notice that this procedure is exactly the same as the procedure described by james, with "lift" replaced by "tension", except for the in the very last step you're just solving for something different.
As for how to make the pretty equations, click on one of our equations to see what we wrote to make it appear.
cookiemonster
15K
29K
