Explain the difference of hyodrogen ions
The pH of a solution is calculated using the formula pH = -log[H], where [H] represents the molar concentration of hydrogen ions. A neutral solution, such as pure water, has a pH of 7, indicating a hydrogen ion concentration of 1 x 10^-7 M. In contrast, an acidic solution with a pH of 3 has a hydrogen ion concentration of 1 x 10^-3 M, while a strong base with a pH of 11 has a hydrogen ion concentration of 1 x 10^-11 M. Understanding these values is crucial for differentiating between acidic, neutral, and basic solutions.
  • Understanding of logarithmic functions
  • Basic knowledge of molarity
  • Familiarity with acid-base chemistry
  • Ability to perform calculations involving exponents
  • Study the concept of molar concentration in solutions
  • Learn about the properties of acids and bases
  • Explore the relationship between pH and hydrogen ion concentration
  • Investigate the use of pH meters for measuring acidity and alkalinity
Chemistry students, educators, and anyone interested in understanding acid-base chemistry and pH calculations.
chemical
The pH of a solution is determined by the value of -log[H] where [H] is the molar concentration of hydrogen ions in the solution
The pH of water is 7, the pH of an acid is 3 and the pH of a strong base solution is 11. Explain the difference of hyodrogen ions in each of these solutions
i have no idea how to get started on this one... 7 = -log7 once again no idea... i know that the answer will be to the negative power like 1/100 but can't get started. help would be appreciated :smile:
[tex]pH = -\log_{10}([H])[/tex]
They give you the values for the left hand side, so plug those in, and solve for the corresponding [H] values. [H] is going to be your unknown here.
cookiemonster
cookiemonster
cheers
