Collision with Spring: Solving for Distance and Final Velocities
  • Thread starter Thread starter kle89
    Collision Spring
The discussion focuses on solving a physics problem involving a collision between two blocks, one of which is equipped with a spring. The first block, weighing 3 kg and moving at 8 m/s, collides with a stationary block of the same mass, which has a spring with a constant of 6 N/m. To determine the maximum compression of the spring, the equation 1/2mv^2 = 1/2kx^2 + 1/2mv'^2 is utilized, where v' is the final velocity of the blocks. The conservation of momentum is applied to find the final velocities post-collision, emphasizing the use of the center of mass frame for accurate calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with the conservation of momentum principle
  • Knowledge of spring mechanics, specifically Hooke's Law
  • Ability to apply energy conservation principles in physics
  • Study the conservation of momentum in elastic and inelastic collisions
  • Learn about energy conservation in spring systems
  • Explore the concept of the center of mass frame in collision problems
  • Practice solving similar problems involving springs and collisions
Physics students, educators, and anyone interested in understanding collision dynamics and energy conservation in mechanical systems.
kle89
Problem
One block (3kg) is moving at 8m/s on a frictionless plane to collide with another block at rest with the same mass, but has a spring in front of it. Spring constant = 6 N/m
a. Determine the maximum distance the spring is compressed.
b. Determine the final velocities of the blocks after the collision. You should assume that the 1 kg and 2 kg blocks remain stuck together.
Honestly i have no idea how to set the equation up? Would i use 1/2mv^2' = 1/2kx^s + 1/2mv^2 to find the distance of the spring? The problem is i wouldn't know what the final velocity would be after hitting the spring so i can't solve exactly for x. Also the other block with the spring could move after the collision so wouldn't its velocity be equal to that of the original block after hitting the spring but in the opposite direction? Any hints to get me on the right track would be appreciated. Thanks in advance.
maybe you can assume that at the point where the 1st block contacts the spring of the 2nd block, the velocity of the 1st block is still 8 m/s... Then you can just look focus on the time frame in which the whole spring compression occurs, knowing that the initial velocity of the 1st block when it contacted the spring was 8m/s.
Part b would most probably involved conservation of momentum law. But you need to solve a.
use center of mass frame!
  • · Replies 37 ·
  • · Replies 20 ·
