Which Temperature Range Cools Faster According to Newton's Law of Cooling?
The discussion revolves around a question related to Newton's law of cooling, specifically comparing the cooling rates of a person transitioning from 150 degrees Celsius to 100 degrees Celsius versus from 100 degrees Celsius to 50 degrees Celsius in a laboratory environment.
  • Exploratory, Assumption checking
  • Participants explore the implications of the temperature differences and question the assumptions regarding the laboratory environment's temperature. Some express uncertainty about the necessary variables, such as the time constant, while others discuss the impact of the initial temperature difference on the cooling rate.
The discussion is ongoing, with participants offering various interpretations of the problem and questioning the assumptions made about the laboratory environment. Some guidance has been provided regarding the relationship between temperature difference and cooling rate, but no consensus has been reached.
There is ambiguity regarding the laboratory temperature, as participants suggest different scenarios and question the lack of specified external conditions. The original poster also notes missing variables that complicate their understanding of the problem.
sunbunny
Hey, I'm having problems with this question:
According to Newton's law of cooling, what cools faster, a person from 150 degress celsius to 100 degrees celsius or 100 degrees celsius to 50 degrees celsius in a laboratory environment? Why?
I' not really sure where to start.
I know the formula for this law is (T-Tr)= (To-Tr)e^-t/time constant
I guess wha I'm confused about is that I don't have some of the variables that I need like the time constant.
If anyone can point me in the right direction it would be much appreicated!
Thanks
The information we get from the equation is that the rate of cooling depends only on the material involved and the initial temperature difference, and it sounds like the material (human) is the same in both cases!
Does this then mean that the body would cool at the same rate in both situations since they both have a temperature difference of 50 degrees celsius?
It doesn't seem clear to me that the "laboratory environment" is 100C in the first instance and 50C in the second. Why can't it be 20C in both? It doesn't say.
Since the external temperature is not specified the only way to interpret the problem to make any sense is to a assume a constant lab temp.
I imagined that the first case had the person[tex]^1[/tex] at 150C, with the lab at 100C, and that the second case has the person[tex]^2[/tex] at 100C and the lab at 50C.
1. Steaming pile of ashes.
2. Boiling goo.
2. Boiling goo.
I really doubt that the lab would be at 212 degrees fahrenheit.
The question is asking whether it takes longer to go from 150>>100 or from 100>>50 in an environment that is 20 degrees to start with.
Temperature loss occurs the faster at bigger differences, and slower when close to equilibrium.
thank you all for you help, I now have some ideas to work with!
