Thread Closed
Killing vector fields
Share Thread Thread Tools
Mar19-07, 02:35 AM   #1
Can a killing vector field generate a diffeomorphism that only shifts points inside a small part of the manifold and preserves points outside of it?
Rotation preserves the metric of a sphere but shifts every points on the sphere, I'd to find out if there is a killing vector field that generates local transformation?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar19-07, 04:58 AM   #2
Quote by kakarukeys View Post
by definition, killing vector fields generate isometries. so, for a global killing v.f. to exist, just find an isometry that fixes the entire manifold except for a "small part" of it. (I'm a bit skeptical about being able to do that, myself)
Mar21-07, 01:59 PM   #3
Tricky question... I think the answer is "no", at least for a connected manifold.
On a "small" part of the manifold, we may as well take the metric to be flat -- so, Minkowski or Euclidean. In n dimensions, flat space has n(n+1)/2 Killing vector fields. Any Killing vector field is a linear superposition of these. And I don't think you can get any linear superposition of these to vanish outside an enclosed region -- which is what you're asking for.
I'm sure there's an elegant way to prove this -- I'd have to think about it more. Maybe someone else will chime in?
Mar22-07, 10:17 PM   #4
I'm thinking if this is a proof:
An isometry preserves the metric, it therefore preserves geodesics. It maps geodesics to geodesics. Assuming the isometry is identity outside a small region, choose three points that are on a geodesics, two outside and one inside the region. The isometry keeps the two points and any point between them outside the region fixed but shifts the 3rd points. So we have two distinct geodesics connecting two points, which is not allowed by ODE's theory, the geodesics equation is a simple ODE that has a unique solution given an initial point and initial velocity.
Thread Closed
Thread Tools
Similar Threads for: Killing vector fields
Thread Forum Replies
killing vector help Differential Geometry 0
killing vector in kruskal coordinates Special & General Relativity 4
Vector Fields and Vector Bundles Differential Geometry 7
Killing fields Differential Geometry 6
what is a time-like killing vector? Special & General Relativity 4
