How Can I Measure the Movement of a Loudspeaker Membrane?
  • Thread starter Thread starter morten84
    Coil
This discussion focuses on measuring the movement and velocity of a loudspeaker membrane, specifically through the movement of the voice coil. Key methods include analyzing the difference between current and voltage supplied to the loudspeaker, utilizing specifications such as Qts, Vas, SPL/W, and Qmax, and employing optical feedback with an encoder setup. For practical experiments, measuring the deflection of the speaker cone when a known amplitude sine wave is applied is essential. Additionally, relating the electrical power drawn by the speaker in Watts to the noise power emitted in dB is crucial for understanding air movement and speaker cone displacement.
  • Understanding of loudspeaker specifications (Qts, Vas, SPL/W, Qmax)
  • Basic knowledge of electrical measurements (current and voltage)
  • Familiarity with sine wave signal generation
  • Experience with optical feedback systems (encoders)
  • Research methods for measuring loudspeaker cone deflection
  • Learn about the relationship between electrical power and sound pressure level (SPL)
  • Explore optical feedback techniques for precise movement measurement
  • Investigate the use of oscilloscopes for analyzing current and voltage waveforms
Audio engineers, acoustics researchers, and students working on loudspeaker design and performance measurement projects will benefit from this discussion.
morten84
Hi, I'm kinda new her, so I hope this is the right place to post this.
English is not my native language, so you might experience some spelling error:)
I am working on a project that my teacher assigned med the other day, were I am supposed to find out how i can measure the movement/velocity of a loudspeaker membran.
To find the movement/velocity of the membran i believe i must fint the movement of the voice coil.
(Not 100% this is the way to go)
Can this be done by measuring the differrent between the current and voltage feeding the loudspeaker?
Anyone have any ideas?
i believe you can get most of the info from Qts, Vas, spl/w and Qmax specs. or with optical feedback with a encoder type setup.
If you are finding the movement of a specific speaker with no specification as a project then you need to design an experiment to physically measure the deflection when a known amplitude sine wave is applied.
If you just have the specifications then you need to relate the electrical power the speaker draws in Watts to the noise power emitted in dB. You should be able to calculate the air movement required for a particular db level in standard atmosphere and then equate that to movement of the speaker cone for an input power.
11K
11K
