Integration By Substitution and Line Integrals
The discussion revolves around the integration of functions using substitution, specifically focusing on the integral of 1/(16 + x^2) and the application of line integrals with parametrization. Participants express confusion regarding the substitution process and the determination of limits in line integrals.
  • Homework-related
  • One participant seeks guidance on how to perform substitution for the integral of 1/(16 + x^2), expressing uncertainty about what to substitute and how to rearrange the equation.
  • Another participant suggests that the integral can be approached by rewriting it in a form that resembles the known integral of 1/(1 + x^2), proposing a substitution of x = 4y.
  • Participants discuss the limits of integration for line integrals, specifically questioning how to derive the limits from the parametrization given by x = t and y = 2t^2.
  • One participant expresses confusion about the limits stated in the problem, noting a discrepancy between the limits of integration and the parametrization.
  • Another participant points out that the parametrization x = 2t^3 and y = t^2 does not pass through the specified points (0,0) and (1,2), suggesting a possible error in the problem statement.
  • A later reply acknowledges the confusion regarding the limits and indicates a willingness to consult the lecturer for clarification.
Participants generally express confusion and uncertainty regarding the substitution process and the limits of integration. There is no consensus on the correct approach to the problems presented, and multiple viewpoints on the parametrization and limits remain unresolved.
Participants note potential errors in the problem statements, particularly regarding the parametrization not aligning with the specified points for integration. There is also mention of confusion stemming from the limits provided in the questions.
Claire84
For our homework this week for Pure, one of the questions is to ingration 1/(16 + x^2) with respect to x between the limits 0 and 4. I know the result from the formula wqith arctan in it, but since we've to use substitituion here and not just plonk down the formula, I'm confused as to what to substitute. Do I need to rearrange this eqt to work it out? I've got in my Applied notes how to differentiate the arctan thing to get this, but it doesn't make sense as to what I've to substitue in because at least when you differentiate you can work with eqt better. Even a hint to set me on the right track would be much-appreciated as I've got the other substituion questions okay but this one is bugging me as there seems to be more to it than the others.
Just one other thin about line integrals that we covered today. They make sense until I see what you've to put into the limits. For example
I= integral from A to B of xydx + integral from A to B of y^2dy
where A=(0,0) and B=(1,2)
The first case is where x=t and y=2t^2 and in brackets beside it has 0<=t<=2
I'vwe done the question and used he limits as 0 and 2, but only because it says beside the question. not because I know why! I mean whyy are the points given then? Do you work the limits out for t from the x=t and y=2t^2 eqts?
To integrate dx/(16 + x^2): Since you already know that the integral of dx/(1+x^2) is arctan(x)+ C, the problem is that "16". If the problem were dy/(16+ 16y^2) then you could write it as
(1/16)(dy/(1+y^2)) and integrate that. Okay, how about x=4y (from
x^2= 16y^2)?
I'vwe done the question and used he limits as 0 and 2, but only because it says beside the question. not because I know why! I mean whyy are the points given then? Do you work the limits out for t from the x=t and y=2t^2 eqts?"
How about looking at it the other way? You are given that the path is x= t and y= 2t^2. When t= 0, what are x and y? When t= 1, what are x and y?
Yes, you work the limits out from x= t and y= 2t^2. You are to integrate "from (0,0) to (1,2)". That is: for the starting point
x= t= 0 and y= 2t^2= 0. Yes, those are true only for t= 0. For the endpoint, x= t= 1 and 2t^2= 2. Again, those are true only for t= 1.
Okay, so I'm only integrating between 0 and 1 then? That's okay, I was confused because beside that question he had put between 0 and 2.
For the second part we have the same points but x=2t^3 and y=t^2 I can't find the same t that works for these apart from 0, so I'm not sure what is to go as my upper limit. Beside this one we have in brackets (0<=t<=1)
Could it be an error in the question? I'm also able to work out the limits from the examples in our notes but for this one (given in the post above) I can't find the uper limit at all. If no one can see a logical answer to it I'll go speak to the lecturer on Monday, but please save me from that.
So the points between which we must find the integral are (0,0) and (1,2)
the parametrization
x=2t^3, y=t^2, does not describe a curve passing through those points. it passes through the point (2,1) at t=1, which strongly suggests a typo - perhaps the x and y got swapped in the typing up.
Thanks for that. I think that was the bit that was confusing me the most about how to work out the limits because I didn't know where the pregnant woman, sorry male lecturer, had got that from. Much-appreciated. Seems I'll have to mention it to the grumpy old bear on Monday, or maybe an email would be a less hairy experiebce. Just kdding, I'm sure he's delightful, really!
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 24 ·
