| Thread Closed |
question about return current in high speed design |
Share Thread | Thread Tools |
| Mar20-07, 01:19 PM | #1 |
I have a question about return currents. Now, all current needs to travel in a loop. so any charge that leaves a source must return to it (correct me if i'm wrong).
usually on a high speed design the return current wants to travel right underneath the trace which is usually the ground plane. when a signal is launched onto a trace, it couples with the plane underneath essentially charging capacitors all it's way down. so electrons on the trace would push out electrons from the plane which return to the negative terminal of the source. say i have a very very badly designed board and have no ground plane but a ground trace that is no where close to the signal trace. would happen if there is no plane and what would it couple with to obtain the return current? Thanks! |
| Mar20-07, 02:58 PM | #2 |
i thought the skin effect ment current would tend to stay all along the outside?
| Mar20-07, 03:06 PM | #3 |
Mentor
In a transmission line, the characteristic impedance is basically the square root of the inductance per unit length divided by the capacitance per unit length.
[tex]Z_o = \sqrt{\frac{L'}{C'}}[/tex] Practical controlled PCB characteristic impedances range from about 50 to 100 Ohms. When you separate the ground return as you describe, it raises the inductance significantly, and you no longer have a controlled transmission line. You have a loop antenna, and more of your energy gets radiated away, plus you get lots of parasitic ringing, because the LC resonance of the loop is probably down in the frequency range of the signal waveform's spectrum. BTW, one important (and often overlooked) aspect of using controlled microstrip transmission lines on PCBs -- You need to keep your signal trace on the side of the PCB that has the inner ground plane layer adjacent to it, and not feed through to the other side of the PCB. For example, with a typical 4-layer PCB stackup, you have the top signal layer, the inner ground plane layer, the inner Vdd plane layer, and the bottom signal layer. You need to route your transmission lines on the top layer only, or you need to add more layers to the PCB where you can run traces adjacent to other ground layers. |
| Mar21-07, 10:48 AM | #4 |
berkeman, thanks for the explanation ! just a couple of follow up questions to fill in the gaps in my understanding.
1. what exactly causes the inductance to rise when you move the return path away? 2. say you had a 2mA draw when the return path was under the trace. When you move it away do we have smaller current draw? 3. Is all charge leaving the source ultimately making it back to the source? Thanks! |
| Mar21-07, 11:02 AM | #5 |
Mentor
[tex]L = \frac{\mu_0 \pi R}{2}[/tex] So the smaller loop area of a trace over ground plane is what keeps the L' in the range where you can get good transmission line behavior, and a consistent [tex]Z_0[/tex] -2- It depends on the source and the excitation frequency. If the source is a voltage source and the frequency is in the range where the inductive reactance becomes comparable to the source impedance of the voltage source, then you will get less AC current. If the source is an AC current source, then you will still get the 2mA AC. You always need to consider the real source characteristics when asking a question like this. -3- Yes, the charges move in the loop of the completed circuit. |
| Mar21-07, 11:36 AM | #6 |
where do you get those 'crib sheets'? do have to make them yourself?
| Mar21-07, 12:04 PM | #7 |
Mentor
I got into the habit back in undergrad of making a good summary crib sheet for each of my technical classes, whether it was allowed on exams or not (generally they were not). It helped me to understand what the key concepts were, and helped me when it came time to study for exams. Particularly in studying for the final, since that covers material that you've learned months ago, and maybe have not applied recently. |
| Mar22-07, 09:47 AM | #8 |
one interesting question regarding reflections in a board... mathematically when there is a mismatch in impedance at the load side, the signal might reflect...the question is what physical phenomenon causes it to really alter the voltage levels at the load side...
| Mar22-07, 10:26 AM | #9 |
Mentor
But when the wave hits a load resistor that is mismatched (or encounters some other discontinuity in the transmission line, like a change in Zo), the current waveform is mismatched for the voltage waveform and the load impedance, but the energy has to go somewhere. The result is a partial reflection of energy, which propagates backwards up the transmission line. Look up info about the "reflection coefficient" if you want more info about reflections at Zo discontinuities. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: question about return current in high speed design
| What would a good design for a High RPM Altenator be? | Mechanical Engineering | 1 | ||
| Current considerations in Electronic design | Electrical Engineering | 6 | ||
| Collisions at high speed vs normal speed | General Physics | 5 | ||
| Wire melts because of high current - help! | Introductory Physics Homework | 9 | ||
| Does Good design influence on high quality products? | Engineering Systems & Design | 2 | ||
