Factors Affecting Energy Gap in Aromatic Compounds
  • Thread starter Thread starter jkh4
    Phenol
The discussion revolves around the factors affecting the energy gap in aromatic compounds, particularly in the context of a lab experiment involving the pKa of phenol. Participants explore concepts related to absorbance curves, isosbestic points, and the influence of molecular structure on energy levels.
  • One participant questions why absorbance curves might not go through the isosbestic point, noting that changes in equilibrium position could be a factor.
  • Another participant clarifies that the isosbestic point is not affected by pH or the protonation state of phenol, emphasizing that only the total concentration of protonated and deprotonated species influences absorptivity.
  • A follow-up post reiterates that the isosbestic point depends on the sum of concentrations rather than individual concentrations, prompting further inquiry about mechanisms that could alter total concentration.
  • Discussion on the HOMO-LUMO gap includes the impact of substituents on absorption wavelengths, with one participant noting that electron-donating groups increase and electron-withdrawing groups decrease the wavelength of absorption.
  • A question is raised regarding the effect of adding alkyl chains on the wavelength of absorption, with no consensus on whether it would increase or decrease the wavelength.
Participants generally agree on the definition and implications of the isosbestic point, but there is uncertainty regarding the effects of specific structural changes on the HOMO-LUMO gap and absorption wavelengths, with multiple competing views presented.
Limitations include the potential dependence on specific definitions of terms like "energy gap" and "isosbestic point," as well as unresolved questions about the influence of alkyl chains on absorption characteristics.
jkh4
please help! questions on pKa of Phenol
Hi, I have some questions regarding the pKa of Phenol lab that I am working on right now.
1) What would cause the absorbance curves to not go through the isosbestic point?
For this one, I know that isosbestic point is not pH dependent so pH won't affect, and definitely true if there is a change in the total concentration of phenol or ratio of phenol to phenolate. But what about a change in the position of the equilibrium?
2) The wavelength of the transition depends on the exact energy difference between either π or n orbitals and the π* orbitals -- in other words, the HOMO-LUMO gap or the n-LUMO gap. When the energy gap becomes smaller, for example by increasing the size of the conjugated system, the absorbance wavelength increases. The question is what kind of factors affect this energy gap (HOMO-LUMO gap or the n-LUMO gap) for aromatic compounds.
3) Why was the rinsing of glassware with acetone not allowed in this experiment?
I know that acetone is UV active so it will give interences also acetone will dissolve the phenol, but will the acetone react with phenol?
Thank you so much for your help =)
Consider the source of the absorbing moiety at the wavelength of the isosbestic point. You have already pointed out that it is not pH dependent. This absorbance is not dependent on the protonation or deprotonation of the phenol. Therefore, the equilibrium point, which only affects the relative concentrations of anion and parent compound, cannot affect isosbestic point.
Only the number of total equivalents of the protonated and deprotonated species will affect the absorptivity. Any change in total concentration of the sum of these two species, by any mechanism, will change the absorptivity at this point.
Can you posit any mechanism that might change the total concentration?
what about the ratio of phenol and phenoate? is that mean the ratio of concentration?
By definition, the isosbestic point is only dependent on the SUM of the concentrations of the protonated and deprotonated species, not the individual concentrations.
Homo Lumo
I also have the same question about HOMO and LUMO gap. I know that adding a electron donating substituent and adding a double bond which is conjugated will increase the wavelength of absorption and adding electron withdrawing substituents will decrease the wavelength of absorption.
But what about adding alkyl chains, will it decrease or increase the wavelength of absorption??
thanks!
  • · Replies 19 ·
10K
63K
