Understanding the Compton Effect: How Light Reflects on a Mirror Explained
  • Context: High School
  • Thread starter Thread starter wolverine
    Stupid
The discussion centers around the reflection of light on a mirror, exploring both classical and modern physics explanations, including the Compton effect and quantum electrodynamics (QED). Participants express curiosity about the nature of reflection and the implications for how images are perceived in mirrors.
  • One participant questions whether the Compton effect is the sole mechanism for light returning to the eyes, suggesting that it implies a change in frequency and color, leading to confusion about the identity of the reflection.
  • Another participant asserts that the reflection in the mirror is indeed the viewer, emphasizing that reflections appear the same aside from inversion.
  • A humorous remark is made about the identity of the reflection, prompting a suggestion to review basic physics concepts related to waves and optics.
  • One participant expresses agreement with the classical explanation of reflection but seeks to understand how modern physics, particularly QED, describes the phenomenon.
  • A question is raised about the velocity of light at the point of reflection, indicating uncertainty about the behavior of light during this process.
  • A participant shares an explanation from a physics instructor, comparing the behavior of light with that of radio waves and discussing the electromagnetic properties of mirrors.
  • Another participant describes the four possible outcomes when light strikes a surface, including transmission, absorption, reflection, or a combination, and relates this to the wavelength of light and material properties.
  • One participant reflects on the need for QED to explain the reflection process, contrasting it with a classical approach that involves interactions between photons and electrons.
  • A further clarification is provided about the classical wave model, explaining how a metal surface reflects light by canceling the electric field at the surface.
Participants express a mix of agreement and differing views on the explanations of light reflection. While some support classical interpretations, others advocate for modern physics perspectives, indicating that the discussion remains unresolved regarding the best explanation.
Participants reference both classical and quantum theories without fully resolving the implications of each approach. The discussion includes assumptions about the nature of light and the behavior of electromagnetic waves at reflective surfaces.
wolverine
Could you explain me how does Light reflect on a mirror?
I assume that Compton effect on electrons is the only way for light to come back to my eyes but in that case, there would be a change of frequency of the photon (and a change of color).
Does it mean that it is not me in the mirror ?
Am I wrong ?
HELP ME, PLEASE ...
Science news on Phys.org
While I can't answer exactly how it happens, I can tell you that it IS IN FACT YOU in the mirror. Doesn't everyone else look the same in the mirror to you as they look normally aside from the inversion?
Is it really wolverine in the mirror? How does he get back out? Go back to your basic physics book and review waves, and optics.
Bring your image with you too. -Mike
I'm agree with you because of the daily experience, but even if optics can explain how ligth reflect on a mirror, I wonder how can modern physics (QED ...) descibe the reflection ...
And at the point of reflection, does light have zero velocity?
My physics instructor at Yale, Prof. Beringer, once explained to me that a mirror was to light as a radar was to radio waves. (Or an oven cavity is to microwaves, I guess.)
Electromagnetic radiation impinging upon a mirror - a conductor in the visible range; EMR cancels at a conductor - thus maintains a potential opposite to that of the incident ray, which manifests in turn with the emission of the image's reflected photonic signal.
Using mirror symmetries likewise helps solve many problems in electrodynamics.
wolverine
If you think of light as a a wave packet of photons, when it stirkes a surface it has four possible outcomes. First, it might travel right through it, like pure glass. Second, it may not travel through it at all but be totally absorbed by it. Thirdly, it may be reflected totally. And lastly, it may be some combination of all of the above. What happens to the light when it strikes the surface depends on the wavelength of the light and the composition of the material it strikes.
For a 100% reflective mirror, the wavelengths cannot penetrate and they reflect. The easiest way to vinsualize this is using the light ray model. But, using QED, as Richard Feynman so aptly describes in his book, QED, we find that the reflection is all about the probability that a photon travels along this path or that depending on the least time it takes.
Hope this is some additional help to you.
Regards
It does , thanks.
I just thought that there were a "classical" explanation, like photons hiting electrons and going back to my eyes or photons passing trough matter without doing any interacion.
Assuming that, I was thinking that R was equal to
Ninteractions
_____________
Ntotal
But it seems that we need to use QED to explain that.
Originally posted by wolverine
It does , thanks.
Sure there's a classical explanation. Light is an electromagnetic wave. The electric field oscillates at the light frequency. But a metal surface "shorts out" the electric field, effectively pinning it to zero at the surface. The wave therefore has no choice but to reflect. It is analogous to waves on a string. Fix one end of the string in place, and the wave you send down the string reflects perfectly. In more detail: the medium outside the mirror permits waves in any direction. But the only wave that when added to the incoming wave always gives zero electric field at the surface of the mirror, is in identical wave coming backward as a reflection.
  • · Replies 172 ·
23K
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 24 ·
17K
