Question about light intensity and resistance
This discussion focuses on using a Light Dependent Resistor (LDR) to measure light intensity in a physics experiment involving diffraction gratings. The key to obtaining accurate light intensity measurements lies in consulting the technical data sheet for the specific LDR part number, which provides essential information on how resistance changes with light intensity and the sensitivity of the LDR across different wavelengths. Understanding these parameters is crucial for designing an effective experimental setup.
  • Understanding of Light Dependent Resistors (LDR)
  • Familiarity with diffraction gratings
  • Knowledge of resistance and its relationship to light intensity
  • Ability to interpret technical data sheets
  • Research the technical data sheets for various LDR part numbers
  • Learn about the principles of diffraction gratings and their application in experiments
  • Study the relationship between resistance and light intensity in LDRs
  • Explore methods for calibrating LDRs for accurate light intensity measurements
Students conducting physics experiments, educators teaching optics, and anyone interested in practical applications of LDRs in measuring light intensity.
jimbobjb
For my physics coursework, I have to design a laboratory experiment using an LDR to investigate how intensity of light emitted from a lamp varies with wavelength. In the procedure I will use diffraction gratings to separate light into wavelengths. The problem I am having is "How a measure of light intensity can be obtained from the LDR" please can anybody show me how to obtain intensity from an LDR.
thanks
You need the technical data sheet for the particular LDR part number you will be using. The data sheet will tell you how the LDR resistance changes with light intensity, and how the sensitivty of the LDR varies with the wavelength of the light.
  • · Replies 45 ·
  • · Replies 25 ·
