Thread Closed
Period of a Mass on a Spring in Simple Harmonic Motion
Share Thread Thread Tools
Mar22-07, 04:40 PM   #1
Kim drives her empty dump truck over a berm (also called a speed bump) at the contruction site. The truck has a mass of 3000kg and the force constant for one of the truck's springs is 100,000N/m (Remember, truck has 4 wheels).
a)What is the resulting period of the bouncing truck as it goes over the bump?
b)If Kim leaves the contruction site with a load of dirt in her truck, what will this do to the period of her dump truck as truck crosses berm?
2. Relevant equations
3. The attempt at a solution
For part B, evaluating the equation and plugging in random numbers.. I'm pretty sure that more mass would result in a longer period..
For part A, what's getting me is the (Remember, truck has 4 wheels) part.
I can do T=2pi[square root (3000kg/(100000N/m)] which comes out to be 1.1s.. Or I don't know if I should multiply or divide or keep the 100000N/m by 4.. I think I've done as much work as I can without going in circles.. Would anyone like to tell me what I should do with the force constant (100000N/m)?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar22-07, 05:05 PM   #2
a) I would just consider the four springs as one big spring with 4 times the spring force constant of one of them.
b) What happens to the mass of the truck if it is loaded with dirt? How does T vary with m in the equation for the period?
Mar22-07, 05:13 PM   #3
More dirt, more mass.. 50/2 is more than 12/2.. square root of 50/12 is more than 12/2 so yeah I'm pretty sure the period is going to be longer. PS, I'm plugging in random numbers for 50 and 12.
Would like more responses.
Mar23-07, 03:57 PM   #4
hello..
PS, save mankind. Distribute your computing power:D
Mar23-07, 10:17 PM   #5
Recognitions:
Gold Membership Gold Member
PugFug, you don't need to plug numbers in to see how mass affects the period. It's in the equation. If m gets bigger then so does T because they're both in the denominator. If k gets bigger T gets smaller because k is in the numerator - in other words you're dividing by k.
Mar23-07, 10:45 PM   #6
I know part b already.. Just wondering about part a..
Mar24-07, 01:25 AM   #7
Recognitions:
Just put the numbers you were given into the formula and calculate.
Mar24-07, 10:20 AM   #8
Did you take into consideration the 4 wheels, one wheel has force constant of 100,000N/m? That could mean a total of 400,000N/m or the stress being reduced across all 4 to 25,000 or the load being the same on all..
Thread Closed
Thread Tools
Similar Threads for: Period of a Mass on a Spring in Simple Harmonic Motion
Thread Forum Replies
[SOLVED] Simple Harmonic Motion (Mass on a Spring) Introductory Physics Homework 3
Simple Harmonic Motion: Mass on a spring Introductory Physics Homework 5
Total energy of a spring-mass system (harmonic motion) Introductory Physics Homework 6
[SOLVED] Simple Harmonic Motion - Period (T) Introductory Physics Homework 2
Simple Harmonic Motion - Period of a Pendulum Classical Physics 23
