Mixing Differential Equation - need confirmation of the process.
The discussion centers on solving a mixing differential equation to determine the flow rate (R) of a ventilation fan needed to reduce impurities in a box of air. The initial amount of impurities is 0.2 pounds, and the goal is to achieve no more than 0.0002 pounds after 4 hours. The differential equation derived is dI/dt = -R * (I(t)/320), leading to the solution I = 0.2 e^(-R/320 * T). Substituting the values results in a calculated flow rate of R = 552.62 cubic feet per hour, confirming the correctness of the approach.
  • Understanding of differential equations
  • Knowledge of mixing processes in fluid dynamics
  • Familiarity with exponential decay functions
  • Basic calculus for integration techniques
  • Study the application of differential equations in fluid dynamics
  • Learn about exponential decay and its implications in real-world scenarios
  • Explore numerical methods for solving differential equations
  • Investigate the impact of flow rate on mixing efficiency in ventilation systems
Students and professionals in engineering, particularly those focusing on fluid dynamics and environmental control systems, will benefit from this discussion.
Malitic
Mixing Differential Equation -- need confirmation of the process.
There is a box with 320 cubic feet of air mixed with .2 pounds of some some impurity. A small ventilation fan is added to the box at one end. Find the flow rate (R) of the fan as such that no more than .0002 pounds of impurities remain in the box after 4 hours.
Variables:
I = the amount of impurities remaining in the box in pounds - @ t = 0, I = .2; @ T=4, I = .0002
R = the flow rate of the fan in cubic feet per hour- unknown must be solved for.
My assumption is that: ( units are in brackets)
[tex]\frac{dI}{dt} = 0 - R \frac{ft^3}{h}* \frac{I(t)}{320} \frac{lbs}{ft^3} = - R * \fracI(t)}{320} \frac{lbs}{h}[/tex]
This equation now can be integrated to find:
[tex]I = .2 e^{-\frac{R}{320} T}[/tex]
Next we plugin the T we have and the impurities (I) at time t, and we get the flow rate of R = 552.62
Up until this point is the work and logic correct?
Yes, it looks good.
Thank you.
10K
