Differential equation: undetermined coeff.
The discussion revolves around solving a differential equation using the method of undetermined coefficients. The original poster seeks assistance in finding the general solution for the equation y'' + 2y' + y = 2e^-t, noting their attempts and confusion regarding the particular solution.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the homogeneous solution and the necessity of adjusting the guess for the particular solution due to resonance. There are questions about the validity of the original guess and the implications of repeated roots on the choice of the particular solution.
Guidance has been offered regarding the need to modify the guess for the particular solution to avoid overlap with the homogeneous solution. Participants are exploring various forms for the particular solution and discussing the algebra involved in verifying their guesses.
There is mention of resonance analysis and its application, with some participants expressing uncertainty about when it is necessary. The original poster also references constraints from their coursework and the need to understand the underlying principles of the methods being discussed.
mrmotobiker
i'm stuck. could someone please help me with this? thanks!
find the general solution:
y''+2y'+y=2e^-t
CE: r^2+2r+1=0
(r+1)^2 which means r1=r2=-1
c1e^-t+c2te^-t
Y(t)=Ae^-t
Y'(t)=-Ae^-t
Y''(t)=Ae^-t
back into the equation:
Ae^-t-2Ae^-t+Ae^-t=2Ae^-t
0=Ae^-t
now I am stuck! what am i doing wrong?! this is the "easiest" problem! isn't the A left there and that's how i find the GS?
the answer is supposed to be c1e^-t+c2tAe^-t+t^2Ae^-t
Have you figured out the homogeneous solution yet? Do that and see if your problem pops out. (Hint: What do you think will happen if you guess the same form as your homogeneous solution?)
but isn't your guess supposed to be Ae^-t because that's what fits. sorry. but not sure if I'm getting your question. thanks for the input.
Yes, typically that would be a good guess at the particular solution, but essentially what happens is that the solution space (general solution) is the superposition of the homogeneous solution and the particular solution. If you add a constant multiple of the homogeneous solution then that will get you nowhere. In other words, if your guess at the particular solution has the same form as the homogeneous solution then you will not find the other linear function in the superposition of the general solution because L1[x] + cL1[x] doesn't really mean anything.
ok i tried Ae^-t+Bte^-t as a guess. but it all canceled out still.
Of course it did. The homogeneous solution is c1e^-t + c2te^-t. Your guess is exactly the same.
You need to try another.
can i have a hint? =) i just tried Ate^-t from another book that says if the assumed solution is a multiplicative function of the homogenous solution and that it should be multiplied by t^m where m is the smallest integer possible. (did i do that right?)
Alright, you were on the right track by continually adding coefficients and higher orders of t.
Did you know that you could solve an equation that only needed Ae^-t with as many higher order terms as you wanted?
Zt^n e^-t + Yt^n-1 e^-t + ... + Bt e^-t + Ae^-t would give the same thing for an equation of say y'' + y = 10e^-t as guessing the lowest order term Ae^-t.
ok, so i tried this:
Ate^-t+Bt^2 e^-t+C (not sure if i need the C)
but after all the algebra, B=1, and I'm not sure how to find A. am i on the right track? based on your explanation...i might be...
ahhhh i tried this like 6 times...
wait. A=C=0? so the solution is homogenous solution+this so it is:
c1e^-t+c2te^-t+t^2e^-t since B=1 -> 1te^-t?
Yep, you got it. It seems like you are not really sure why A and C are zero though.
So if you guess the particular solution
[tex]y_p(t) = Ae^-t + Bte^-t + Ct^2e^-t[/tex]
You will find a huge mess in your particular solutions. After a lot of algebra, which you have to be careful with and really just take it slow, you will find that
[tex]2e^-t = 2Ce^-t[/tex]
multiply the equation by e^t and C = 1.
The other coefficients are completely gone, and so they must be zero.
Thus, the particular solution will be [tex]y_p(t) = 0e^-t + 0te^-t + 1t^2 e^-t[/tex].
The general solution is the superposition of the homogeneous and particular.
Ah crap, I forgot brackets. Just note that every time you see a e^-*t I really meant to do e^(-t). Don't really want to fix it. :)
ok great, thanks! you've been a lot of help. but i guess i still made a mistake because my guess was Ate^-t+Bt^2 e^-t+C instead of Ae^-t+Bte^-t+Ct^2e^t. so just to confirm, the guess should be At^-t + Bt^-t + Ct^2e^-t? i thought it was just to multiply the homogeneous solution by a factor of t...sorry...taking a while to digest, this stuff is still really new.
Yeah, you should have had my guess, which is really (A + Bt + Ct^2)e^-t if that helps you see it a little clearer. You just have to make sure your guess at the particular solution doesn't copy the homogeneous solution because it will not have the range (solution space) as the homogeneous.
Say you had a homogeneous solution of c1e^t + c2t^2e^t + c3t^3e^t + c4t^4e^t then your particular would have to have one higher order than the homogeneous y_p = (A + Bt +Ct^2 + Dt^3 + Et^4 + Ft^5)e^-t.
You don't need all of (A+ Bt+ Ct2)e-t. Since both e-t and te-t are solutions to your homogeneous equation, try y= At2e-t.
great, thanks everyone. ok I'm just practicing problems now since i have a midterm coming up. I'm using schaum's outlines: differential equations. here's the problem:
y''-2y+y=t^2-1
CE: (r-1)^2, r1=r2=1
yh=c1e^t+c2te^t
GS=yh+yp
my guess: yp=At^2+Bt+C
yp'=2At+B
yp''=2A
(question: since it's a repeated root, should i multiply my guess by a factor of t?)
so after all the algebra, i got yp=t^2-4t-11
the book solution is yp=t^2+4t+5; GS=c1*e^t+c2*te^t+t^2+4t+5
did i make an algebra mistake? i went through and looked, it doesn't look like it. did i choose my guess wrong? why?
y''-2y+y=t^2-1
I assume you mean y"- 2y'+ y= t^2- 1
yh=c1e^t+c2te^t
GS=yh+yp
yp'=2At+B
yp''=2A
Since your solution to the entire equation does not involve et, no.
yp"= 2A
yp'= 2At+ B so -2yp'= -4At- 2B
yp= At2+ Bt+ C
yp"- 2yp'+ yp= 2A- 4At- 2B+ At2+ Bt+ C
= At2+ (B-4A)t+ (2A- 2B+ C)= t2- 1
so we must have A= 1, B- 4A= 0, 2A- 2B+ C= -1.
B- 4(1)= 0 so B= 4, 2(1)-2(4)+ C= -1 so C= -1+ 8- 2= 5
I suspect that you lost track of signs!
i just realized. for the first problem, my professor said resonance analysis must be performed. how do you know when you need to do this?
What do you, and your professor, mean by resonance analysis?
umm well he said resonance analysis is make r = alpha + beta*i s=# of times r appears as a root of CE. the equation he keeps using is:
y=t^s * e^(alpha*t) * (An * cos(beta*t) + Bn * sin(beta*t))
i'm not sure when to apply this, but one of my classmates said i am supposed to perform this analysis to get Ate^-t as a guess
is that an easier...or more precise way of making a "guess?"
Ah, I see. The equation for the "resonance analysis," is merely a simplified form of what you would find through normal second order ODE methods. If you have an equation of the form ay'' + by' + ky = f(t), and the coefficients for 'a,' 'b,' and 'k' produce complex solutions then the homogeneous will be the form that you listed (except for the t^s out front, for which I am not sure of where it came in).
I would say to memorize the solution (what you have without the t^s) for an underdamped oscillator for your test, since deriving it will waste time, but you should definitely know how to get to that point. Or if you are allowed to leave the solution in it's complex form then just use the normal method of finding the characteristic roots, aka eigenvalues.
Anyway, the second problem you listed is a case of a critically damped oscillator, and will not have the solution you are talking about. The critically damped solution is simply an example of a repeated real root.
ok that makes more sense. thanks again.
oh, the professor said the t^s is there just in case if there is "resonance." the s is the number of times the root appears in the CE; but i am really unsure why did he put the t^s, i haven't seen this in the books I'm using.
  • · Replies 23 ·
