Differential equations - 2nd order nonhomogenous eq'n
The discussion focuses on solving the second-order homogeneous differential equation (1+t²)d²y/dt² - 2tdy/dt + 2y = 0, with a known solution y1(t) = t. The user attempts to find the general solution by applying the reduction of order method, defining u(t) as u(t) = exp(-∫(-2t/(t+t²) dt)) / y1²(t). The final solution is expressed as y(t) = c1t - c2(t² - 1), where c1 and c2 are constants. The correctness of the approach is questioned, particularly regarding the clarity of the formulas used.
  • Understanding of second-order differential equations
  • Familiarity with the reduction of order method
  • Knowledge of integration techniques
  • Ability to manipulate and simplify algebraic expressions
  • Study the reduction of order method for solving differential equations
  • Learn about the Wronskian and its application in determining linear independence of solutions
  • Explore integration techniques relevant to differential equations
  • Review the theory behind homogeneous and nonhomogeneous differential equations
Students and professionals in mathematics, particularly those studying differential equations, as well as educators seeking to clarify methods for solving second-order homogeneous equations.
braindead101
differential equations - 2nd order homogenous eq'n
sorry the title should read 2nd order homogenous eq'n, not nonhomogenous
Find the general solution of the equation:
(1+t^2)d^2y/dt^2 - 2t dy/dt + 2y = 0, given that y1(t) = t is one solution.
My attempt:
divided equation by 1+t^2
d^2y/dt^2 - 2t/1+t^2 dy/dt + 2/1+t^2 y = 0
using u(t) eq'n given:
u(t) = exp(-integ(- 2t/t+t^2 dt)) / y1^2(t)
let x = 1+t^2
dx/dt = 2t
dt = dx/2t
u(t) = exp(integ(2t/x dx/2t)) / t^2
u(t) = exp(integ(1/x dx)) / t^2
u(t) = exp(ln x) / t^2
u(t) = e^ln(1+t^2) / t^2
u(t) = (1+t^2) / t^2
u(t) = (1+t^2)/(t^2)
using y2(t) eq'n given:
y2(t) = t integ (u(t)dt)
y2(t) = t integ ((1+t^2)/(t^2)dt)
y2(t) = t [ integ(1/t^2 dt) + integ (1 dt)]
y2(t) = t[-1/t + t]
y2(t) = -1 + t^2
y(t) = c1y1 + c2y2
y(t) = c1t + c2[-1 + t^2]
y(t) = c1t - c2[t^2 - 1]
can someone please confirm whether i am doing this correct?
My attempt:
What "u(t) eq'n" are you talking about? And why write "y1^2(t)" when you know y1= t?
let x = 1+t^2
dx/dt = 2t
dt = dx/2t
and what "y2(t) eq'n" were you given?
Are you using formulas in your textbook? We can't very well tell whether what you are doing is correct or not if we don't know what formulas you are using.
y2(t) = t[-1/t + t]
y2(t) = -1 + t^2
y(t) = c1y1 + c2y2
Since you did not explain what you are doing I can't tell whether it is or is not correct. I can say, since it is obvious, that your final y satisfies the differential equation. Surely you had already seen that.
sorry
the equations i used are the following:
u(t) = exp(-integ(b/a dt))
and
y2(t) = y1(t) integ (u(t) dt)
  • · Replies 105 ·
13K
