Differential equations - 2nd order euler eq'n
The discussion revolves around a second-order Euler differential equation given by t^2 d^2y/dt^2 + at dy/dt + by = 0, where t > 0. Participants are tasked with showing that t^r is a solution under certain conditions and exploring a second solution involving (ln t)t^(1-a)/2.
  • Participants discuss substituting t^r into the equation to verify it as a solution and question the implications of the condition r^2 + (a-1)r + b = 0. There is also exploration of the second part of the problem regarding the solution (ln t)t^(1-a)/2 and confusion about the substitution process.
Some participants have made progress by substituting t^r into the equation and deriving the characteristic equation. Others express uncertainty about the second part of the problem and seek clarification on the substitution of (ln t)t^(1-a)/2, indicating a lack of consensus on the approach.
There is a noted confusion regarding the constants a and b, particularly in relation to the condition (a-1)^2 = 4b, which some participants have misinterpreted. This has led to questions about the validity of their substitutions and the overall setup of the problem.
braindead101
(a) Let alpha (a) and beta (b) be given constant. show that t^r is a solution of the Euler equation
t^2 d^2y/dt^2 + at dy/dt + by = 0 , t>0
if r^2 + (a-1)r + b = 0
(b) suppose that (a-t)^2 = 4b. Show that (ln t)t^(1-a)/2 is a second solution of Euler's equation.
please help, i have no idea how to start this.
for (a) it says, shown that t^r is a solution, so can i just substitute in ?
Indeed! If y=f(t) is a solution, then it satisfies the differential equation.
Yes, that's how you show that anything is a solution to any equation!
However, "suppose that (a-t)^2= 4b doesn't make sense- a and b are constants while t is a variable. Surely you mean "suppose that (a-1)^2= 4b", in which case the "characteristic equation" r2+ (a-1)r+ b= 0 has (1-a)/2 as a double root. Again, just let y= (ln t)t(1-a)/2 and show that that satisfies the equation in the special case (1-a)2= 4b.
Am I doing something wrong.
I substituted y(t) = t^r in , and end up getting r^2 + (a-1)r + b = 0
here is my work:
y(t)=t^r
y'(t) = rt^(r-1)
y'(t) = r(r-1)t^(r-2)
t^2(r)(r-1)t^(r-2) + atrt^(r-1) + bt^r = 0
r(r-1)t^r + art^r + bt^r = 0
r(r-1) + ar + b = 0
r^2 - r + ar + b = 0
i have no idea what to do now
It might help to go back and read the question again! It said: ". show that t^r is a solution of the Euler equation
if r^2 + (a-1)r + b = 0"
Isn't that exactly what you just did? Replacing y by rt satisfies the equation (makes it equal to 0) if and only if your last equation r2+ (a-1)r+ b= 0.
Now do the same for tr2, remembering that you now have the additional requirement that "(a-1)2= 4b" (NOT (a-t)2!).
ohh, wow i totally forgot about the if r^2+(a-1)r + b=0 part, thanks.
but for (b), why "do the same for tr^2", why am i not subbing in the (ln t)t^1-a/2
can anyone help with this?
i have tried subbing in (ln t)t^1-a/2 but i do not get 0, so i know i am doing somethi gnwrong and it's not my work that's wrong as I've done it twice with the same answer. it keeps coming out to a^2 - 3 = 0
yo
braindead, do u by chance to queen's
Please, read the question again! You did say that a second part of the problem was to show that (ln t)t^(1-a/2) was a solution if (a-1)2= 4b (at least I think that is your equation. I asked if you had a typo and you never answered my question).
Good. You now recognize that you must substitute x= (ln t)t^(1-a/2) (those parentheses are necessary: t^1- a/2 is t- a/2.) using the condition that (a-1)2= 4b. I don't see how we can tell what you did wrong if you don't show exactly what you did. What are x' and x"? What equation did you get?
  • · Replies 18 ·
