Refinery Expertise: Enhancing Propane/Ethane Streams and Quench Processes
  • Thread starter Thread starter katchum
    Quench
The discussion focuses on optimizing ethene production from propane/ethane streams in refinery processes. Key strategies include utilizing high temperatures to favor ethene over propene and managing steam ratios and pressures effectively. The sequence of operations is critical; a compression step before acid removal is necessary to minimize material issues with acid gases like H2S. Additionally, water removal is strategically placed after compression to enhance acid solubility in water, thereby optimizing the overall process.
  • Understanding of ethane cracking processes
  • Knowledge of refinery operations and sequence of chemical reactions
  • Familiarity with acid gas management, specifically H2S
  • Basic principles of thermodynamics related to high-temperature reactions
  • Research the role of catalysts in ethane cracking
  • Learn about the effects of pressure on reaction yields in petrochemical processes
  • Study the principles of acid gas scrubbing techniques
  • Explore advanced water removal methods in refinery operations
Refinery engineers, chemical engineers, and professionals involved in petrochemical process optimization will benefit from this discussion.
katchum
Does anyone know how to get more ethene out of a propane/ethane stream? I know you can use a higher temperature, but can you do something with the steam ratio or pressure too?
Also:
After the reaction, we use a quench with water injection. Why should we do a compression step first before removing the acid components of the stream? And why would we remove the water at the end of all the compression steps and not after the quench?
Anyone an expert in refinery here?
Thanks
Well, I am an old retired ChE that used to work on refining process design years ago and may be a bit rusty. I have never worked on an ethane cracker, but low pressure should assist the reaction since more moles are being produced than consummed. High temperature helps endothermic reactions. I believe a catalyst is required to assist the reaction.
As to water removal after compression is because it is liquid not gas (steam). If acid gas is present (H2S) that should be removed before condensation to minimize material problems.
But that doesn't answer how to get more ethene than propene. (pressure wise)
As for the temperature I know you have to have a very high temperature, because ethene is favored over propene this way.
About the water: I thought that after the quench the steam would have already condensed, so it is removable? But I think, I think...: when you compress everything, there will be more acid soluble in the water so you don't have to scrub the acid gas and waste precious alkaline solution. You can then let some acid solvate into the water and then remove the acid water.
What I don't understand is: why:
quench - compression - acid removal - compression - water removal
Why don't they just do:
quench - acid removal - compression - water removal
  • · Replies 35 ·
  • · Replies 26 ·
17K
