Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Zeros of a function Share It Thread Tools Search this Thread image
Old Mar23-07, 02:06 PM                  #1
Dragonfall
Dragonfall's Avatar
Dragonfall is Offline:
Recognitions:
PF Contributor PF Contributor
Zeros of a function
Does there exist a continuous function LaTeX Code: f:\\mathbb{R}\\rightarrow\\mathbb{R} such that f is nowhere constant and LaTeX Code: \\{x:f(x)=0\\} is uncountable?
Old Mar23-07, 02:09 PM                  #2
neutrino
neutrino is Offline:
Sure there is.
Old Mar23-07, 02:27 PM                  #3
Dragonfall
Dragonfall's Avatar
Recognitions:
Can you give an example?
Old Mar23-07, 03:36 PM                  #4
ZioX
ZioX is Offline:
Well....the irrationals aren't countable...
Old Mar23-07, 04:21 PM                  #5
matt grime
Math Guru 2008
matt grime is Offline:
Recognitions:
Homework Helper Homework Helper
That is a misleading answer - any continuous function that is zero on the irrationals is 0 everywhere. [0,1] is uncountable, and surely anyone can think of a function that is
1) continuous
2) non-constant
3) 0 on [0,1]
Old Mar23-07, 04:32 PM                  #6
Eighty
Eighty is Offline:
He said that f is nowhere constant.
Old Mar23-07, 05:03 PM       Last edited by Dragonfall; Mar23-07 at 05:21 PM..            #7
Dragonfall
Dragonfall's Avatar
Recognitions:
Yes, I did say f is nowhere constant. If f=0 on the subset of irrationals of some interval, then continuity implies that f=0 on that interval.
Intuitively, what I want is a everywhere continuous nowhere differentiable function that is "straight" enough so that a horizontal line intersects the values uncountably many times. I don't think such a function exists, but I can't prove it either way.
The "continuous but nowhere differentiable" requirement might not be necessary, or even relevant, but it's a good place to start looking.
Old Mar23-07, 05:50 PM                  #8
Moo Of Doom
Moo Of Doom is Offline:
Take the function f(x) = 0 on [0,1]. Now replace f on the interval [1/3,2/3] with a triangle wave. Now replace f on the intervals [1/9,2/9] and [7/9,8/9] with a similar triangle wave. Repeat this process for every interval on which f is zero, and we have a continuous function that vanishes on the Cantor set (which is uncountable), and is nowhere constant. Replacing the triangle wave with a suitable LaTeX Code: C^{\\infty} function yields an infinitely differentiable function that vanishes uncountably many times but is not constant. If you want it to be continuous but nowhere differentiable, replace each triangle wave with such a function instead.
Old Mar23-07, 08:10 PM                  #9
ZioX
ZioX is Offline:
Whoops. Missed the continuity assumption.
Old Mar23-07, 11:58 PM                  #10
sauravbhaumik
sauravbhaumik is Offline:
Can you please "formally" define your function? "if we infinitely repeat..." is not a formal term and I am not sure the ultimate function remains a continuous one.
Old Mar24-07, 12:33 AM       Last edited by Moo Of Doom; Mar24-07 at 12:37 AM..            #11
Moo Of Doom
"if we infinitely repeat..." simply refers to the limit function of the sequence of functions I described.
Define
LaTeX Code: <BR>f_1[a,b](x) = \\left\\{<BR>\\begin{array}{cc}<BR>0 & x \\in \\left[a,\\frac{2a+b}{3}\\right]\\cup\\left[\\frac{a+2b}{3},b\\right]\\\\<BR>x-\\frac{2a+b}{3} & x \\in \\left[\\frac{2a+b}{3},\\frac{a+b}{2}\\right]\\\\<BR>\\frac{a+2b}{3}-x & x \\in \\left[\\frac{a+b}{2},\\frac{a+2b}{3}\\right]<BR>\\end{array}<BR>
and
LaTeX Code: <BR>f_{n+1}[a,b](x) = \\left\\{<BR>\\begin{array}{cc}<BR>f_n\\left[a,\\frac{2a+b}{3}\\right](x) & x \\in \\left[a,\\frac{2a+b}{3}\\right]\\\\<BR>x-\\frac{2a+b}{3} & x \\in \\left[\\frac{2a+b}{3},\\frac{a+b}{2}\\right]\\\\<BR>\\frac{a+2b}{3}-x & x \\in \\left[\\frac{a+b}{2},\\frac{a+2b}{3}\\right]\\\\<BR>f_n\\left[\\frac{a+2b}{3},b\\right](x) & x \\in \\left[\\frac{a+2b}{3},b\\right]<BR>\\end{array}<BR>
Then LaTeX Code: f(x) = \\lim_{n\\to\\infty}f_n[0,1](x) is the function I just described.
Old Mar24-07, 12:39 AM       Last edited by Hurkyl; Mar24-07 at 12:42 AM..            #12
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
There's a simpler description of (something like) Moo's function:
f(x) = [distance from x to the Cantor set]
Incidentally, I don't think I've heard "nowhere constant" before -- I would have used the phrase "locally nonconstant".
Old Mar24-07, 01:07 AM                  #13
sauravbhaumik
Define
and
Hmm.. each f_n is uniformly continuous, then if the seq {f_n} converges uniformly, the trick is done.
For the triangular waves become more little as n surges up, I think the convergence is uniform. But, can you dfevise a formal, maybe inductive, proof?
Old Mar24-07, 03:51 AM       Last edited by AKG; Mar24-07 at 04:01 AM..            #14
AKG
AKG is Offline:
Recognitions:
If C is a closed uncountable set in R containing no intervals (like the Cantor set), then it's complement is a countable union of disjoint open intervals. Define f to be 0 on C, and f is a triangle of slope with absolute value 1 on each open interval. So let C be the Cantor set. LaTeX Code: \\mathbb{R} = (-\\infty ,0) \\sqcup \\bigsqcup (a_n,b_n) \\sqcup C \\sqcup (1,\\infty ) . Define LaTeX Code: f : \\mathbb{R} \\to \\mathbb{R} by:
LaTeX Code: f(x)=\\left\\{\\begin{array}{cc}x,&\\mbox{ if }<BR>x < 0\\\\ \\frac{b_n-a_n}{2} - |x - \\frac{b_n+a_n}{2}|, & \\mbox{ if } a_n < x < b_n\\\\ 0, & \\mbox{ if } x \\in C\\\\ 1-x, & \\mbox{ if } x > 1\\right.
image image
Reply
Thread Tools
Similar Threads for: Zeros of a function
Thread Thread Starter Forum Replies Last Post
Meaning of Zeros of Partition function mhill Atomic, Solid State, Comp. Physics 9 Apr17-08 10:09 AM
Zeros of the partition function mhill Quantum Physics 1 Mar18-08 04:32 AM
zeros to function of 2 variables, Matlab. malawi_glenn Math & Science Software 1 Nov10-07 11:31 AM
Finding Zeros of a function jai6638 Introductory Physics 14 Jan25-05 05:40 PM
Find the zeros of the function: JBauer Introductory Physics 10 Jan20-05 05:23 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
