Find Center of Circle Inscribed in Parabola y=x^2
  • Thread starter Thread starter Weave
    Circle Parabola
The problem involves finding the center of a circle with a radius of 1 that is inscribed in the parabola defined by the equation y=x^2. The context includes a visual representation of the circle positioned on the y-axis.
  • Participants discuss the relationship between the equations of the circle and the parabola, questioning how to set them equal to each other. There are attempts to derive equations based on the geometry of the situation, with some participants seeking clarification on the steps taken by others.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions made about the inscribed circle. Some guidance has been provided regarding the symmetry of the problem and the equations involved, but no consensus has been reached on the specific approach to take.
There is a noted lack of visibility for the figure referenced in the problem, which may affect the understanding of how the circle is inscribed in the parabola. Participants are also grappling with the implications of the derivatives and equations involved in the problem.
Weave
A circle with a radius of 1inscribed in the parabola y=x^2, find the center of the circle. The figure shows the circle on the y-axis.
[tex]y=x^2[/tex]
[tex]r^2=(x-h)^2+(y-k)^2[/tex]
h=0. [tex]\frac{x^2+(y-k)^2}{r^2}=x^2[/tex]
R^2=1 and the x^2 can be subtracted out leaving:[tex](y-k)^2=0[/tex] take the derivative of each side, find y, substitute that back in and find k but I end up with other varibles to solve.
How did you get this equation?
setting one equation equal to another
And how did you do that? Can you show some work because I cannot see what you set equal to what.
The equation of the circle and the equation of the parabola are describing different curves. They do NOT always have the same (x,y) values!
Unfortunately, we can't see the figure you talk about. In what sense is the circle "inscribed" in the parabola? Is it tangent to the parabola at two points?
From symmetry, it should be obvious that the circle has center on the y-axis. That is, that the equation of the circle is x2+ (y- h)2= r2.
The derivative of y= x2 is y'= 2x and the derivative of y in x2+ (y-h)2= r2 is given by 2x+ 2(y- h)2y'= 0.
You have 4 equations: y= x2, x2+ (y-h)2= r2, y'= 2x, and 2x+ 2(y-h)2= 0 to solve for four unknown values: the (x,y) values of points of intersection, h, and r.
  • · Replies 21 ·
