From Christoffel symbols to connection 1-forms
The discussion revolves around converting Christoffel symbols into connection 1-forms. A key relationship is established, indicating that the connection 1-form can be expressed using a non-coordinate basis and the Christoffel symbols. Participants emphasize the importance of understanding the symmetries of connection 1-forms, particularly in the context of Riemannian versus Lorentzian manifolds. The conversation references textbooks like Misner, Thorne, and Wheeler, and Harley Flanders for foundational concepts and computations related to connection 1-forms. Ultimately, the discussion highlights the necessity of a proper mathematical framework to effectively transition from Christoffel symbols to connection 1-forms.
cosmicstring1
I have Christoffel symbols for a metric and I want to find the connection 1-forms.
I have the relation:
w(^i j)=Chr(^i j k)*dx(^k)
w: conn. 1-form
Chr: Christoffel symbols
But Christoffel symbols do not share the symmetries of the conn. 1-forms. Do you know any way to make this possible?
Have you studied the relevant chapter in Misner, Thorne, and Wheeler, Gravitation? Or the textbook by Harley Flanders, Differential forms, with applications to the physical sciences? These books offer clear introductions to computing the connection one-forms, as do many others.
w: conn. 1-form
I'm not aware of anything called the connection 1-forms. All I've heard are Chjristoffel symbols of the first and second kind. Are you sure that is not what you're referring to?
Pete
Your relation is incorrect.
You're going to have to pick a set of orthonormal basis vectors compatible with your metric, then either compute the connection from them, or use them with your Christoffel symbols to get the connection.
This is laid out in detail here:
http://deferentialgeometry.org/#[[Christoffel symbols]]
w: conn. 1-form
Firstly, begin by taking \{\hat{\theta}^i\} to be a non-coordinate basis. This non-coordinate basis is related to the coordinate basis \{dx^i\} by
\hat{\theta}^i = \theta^i_{\phantom{i}j}dx^j
for some matrices \theta^i_{\phantom{i}j}. Then the relationship between the connection one-form and the Christoffel symbols is
\omega^i_{\phantom{i}j} = \Gamma^i_{\phantom{i}jk}\hat{\theta}^k
Thus, if you know the Christoffel symbols and the relationship between the non-coordinate and coordinate bases, the answer to your question is to simply read off the value of the components of the connection one form from the above.
Pete
He was perfectly clear when he said he was interested in the components of the connection one-form. This is a basic idea covered in, for example, the first few lectures of any decent differential geometry course.
Consider the frame bundle, which is a principal SO(n)-bundle. (At least, it is for a Riemannian manifold)
If you have any curve, you can take a frame at one endpoint and invoke your connection to parallel transport it to become a frame at the other endpoint. In particular, we get an element of SO(n) detailing how the frame was rotated/twisted/whatever as it was parallel transported along the curve.
If we differentiate (i.e. if we parallel transport by an infinitessimal amount), then to each tangent vector at a point, we get an element of so(n). Since this gives an so(n) value to each tangent vector, and is a linear functional, we call this object a "so(n)-valued one-form".
This so(n)-valued one-form completely determines parallel transport (you integrate it along a curve to get an SO(n) value), thus the term "connection 1-form".
Your relationship is correct, although i don't like to call them the christoffel symbols, i prefer to use the term connection co-efficients since they rely on the second half of the levi-civita connection to calculate.
your wijk = 1/2( g(ek,[ei,ej]) - g(ei,[ej,ek]) - g(ej, [ek,ei]) )
where ei, ej, ek are the othronormal vectors prescirbed by your metric.
Yes, I read that section from MTW but it does not give the answer. I do'nt have Flanders' book.
w: conn. 1-form
What is a connection 1-form. Please defined the term for me.
Thank you
Pete
Thank you
Pete
Well, presumably you're familiar with the idea of using a coordinate basis \{dx^i\} in differential geometry, right? Presumably you're also familiar with the idea that in many practical situations it's a far smarter idea to use a non-coordinate basis \{\hat{\theta}^i\}. Well, if you know about these things it's a simple step to define a matrix-valued one-form [\omega^i_{\phantom{i}j}] as
\omega^i_{\phantom{i}j} \equiv\Gamma^i_{\phantom{i}jk}\hat{\theta}^k
That's really all there is to it. Once you have defined the matrix-valued connection one-form like this, it's a simple matter to go on and show that a neat and tidy way to express the curvature and torsion associated with a given metric is to use the Cartan structure equations.
Hi, cosmicstring, you asked:
I suggested starting from a frame field, a la Cartan, as explained in MTW. I didn't answer the question you asked, I told you where to find the answer to the question you should have asked. You replied:
Sure it does--- look at the sections on computing curvature. This contains what you need to answer the question you asked, as well as showing you a much better way to do all this stuff.
I don't think that even makes sense!
But there is one small point concerning the symmetry properties of the matrix of connection one-forms which MTW slur over. Flanders doesn't cover it either because he only discusses Riemannian manifolds. Namely, the rule for adjoint is a bit different for Lorentzian vice Riemannian. You need to know this when you use the symmetries of the connection one-forms in order to read off the connection one-forms from the exterior derivatives of the basis one-forms, as suggested by Cartan.
By definition, if A is some linear operator and (\cdot , \cdot) is some inner product, the adjoint A^\ast is the linear operator satisfying
(Ax, y) = (x, A^{\ast} y)
for all x,y. If you write this out in matrix notation, with the inner product written (x,y) = x^T L y, you obtain
x^T \, A^T \, L \, y = x^T \, L \, A^{\ast} \, y
This holds for all x,y, so
A^\ast = L^{-1} \, A^T \, L
Now apply this when L = \operatorname{diag} (-1,1,1,1) to obtain the Lorentzian transpose. Now apply this to your matrix of one-forms when reading off the connection one-forms as suggested by Cartan.
In the past I have gone through all this stuff in great detail--- you can Google for old posts by myself in sci.physics.*
I didn't say he wasn't clear. I mentioned my uncertainty about them once before but it now appears that such things exist, hence the new question, i.e. what are they? That was why I was asking him. No textbook that I have on this subject matter even mentions is. Can you please give me an example? Thank you.
Pete
Never mind. I finally found it defined in Lovelock and Rund. Thanks for the help folks. :smile:
Pete
  • · Replies 18 ·
  • · Replies 16 ·
