Force, Mass & Acceleration: Examining the Relationship
The discussion revolves around the relationship between force, mass, and acceleration, specifically examining Newton's laws of motion. Participants are exploring how these concepts interrelate and what hypotheses can be formed based on this relationship.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are attempting to articulate a hypothesis regarding the relationship between force, mass, and acceleration. Questions are raised about the specifics of Newton's law and how to experimentally verify the relationship. There are inquiries about the interpretation of data and the validity of experimental results.
The discussion is ongoing, with participants seeking clarification on the relationship between the variables and how to formulate and test hypotheses. Some guidance has been offered regarding the need for precise definitions and experimental setups, but there is no explicit consensus on the correctness of the interpretations presented.
Participants are working within the constraints of homework guidelines, which may limit the depth of their explorations. There are also questions about the clarity of the experimental setup and the accuracy of the data being discussed.
raman911
Force, Mass and Acceleration
Purpose: - What relationship exists between the acceleration of an object, its mass, and the net force applied?
Hypothesis: -
i need help to write Hypothesis
can u help me
Read this introduction (what textbook are you using?), and then tell us what the relationship is between force F, mass m, and acceleration a.
http://en.wikipedia.org/wiki/Newton's_laws
i read it
it is Newton law
any one help me
Spell out Newton's law -- what is the equation relating F, m and a?
Once you have that equation, what would you hypothesize about a, if you knew the mass of an object and the force applied to it? How would you go about testing this hypothesis?
I Have That Result
Can U Check
Is That Right?
PLZ CHECK LAST ONE MASS*acceleration
IS THAT RIGHT?
Parts of it do not look correct. First, what's a cart? Are you using carts of different masses or different numbers of carts or something to check F=ma experimentally?
Also, I don't know what the [F] is at the top of each column. The letter "F" is usually reserved for force, and units are usually put in square brackets []. You can leave the units in the round parenthesis () if you want, but what is meant by [F]?
is my mass*acceleration colum right or wrong?
please reply anyone
Hard to tell, but the numbers looked cooked up, instead of being the results of an experiment. Is this just a thought experimen? What exactly is the problem statement? Please be specific.
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 25 ·
