Finding Derivative of y=3x(x-4)(x+2)
  • Thread starter Thread starter dcgirl16
    Derivative
The discussion revolves around finding the derivative of the function y=3x(x-4)(x+2), which falls under the subject area of calculus. Participants are exploring different methods for approaching the derivative calculation.
  • Mixed
  • Participants are considering whether to multiply out the terms before applying the product rule or to apply the product rule directly. There are questions about the correct order of operations and whether to multiply all factors together or just some of them.
Some participants suggest multiplying the terms out first, while others emphasize the importance of understanding the product rule for multiple factors. There is a recognition that different approaches may yield the same result, and participants are encouraged to explore both methods.
One participant notes that it is generally preferable to simplify before applying derivative rules, and there is a mention of the original poster's uncertainty regarding the multiplication of factors.
dcgirl16
if I am trying to find the derivative of y=3x(x-4)(x+2) do i multipy the 3x through first or go right to the product rule ad if i do multiply it through do i multipy it through both terms
(3x^2-12x)(3x^2+6x) or
3(3x^2-12x)(x+2)
Thread moved to Homework Help, Calculus. dcgirl16, homework and coursework questions belong in the appropriate Homework Help forum, not in the main forums.
And on your question, for me it's easiest to multiply it out first before taking the derivative, at least in this particular problem.
multiply everything out, like you did in your first suggestion, but then multiply those together ((3x^2-12x)(3x^2+6x)) then take the derivative.
DO NOT MULTIPLY BOTH FACTORS BY THE FIRST FACTOR. Multiplication doesn't work that way! Jeez! And you should get the same answer no matter how you do it. If you are dubious it's worth trying both ways.
Also, have you derived the product rule for the product of 3 factors yet? Generally, it's nicer to simplify before applying derivative rules than it is to simplify after taking the derivatives.
  • · Replies 25 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 44 ·
